08-10-2016, 10:24 AM
Side to side leveling
Just returned from my FIRST trip with my new ROO 19', everything went Great, my only question is there an easy way to level side to side, My daughter and son-in- law placed 2x6 on ground then backed up over them, ok but very slow, can I take a bottle jack and raise the low side up and then place the boards under the wheels. OH one last question: dumped a black tank for the first time EVER, how do I know if I got it cleaned out good enough? Is there a way to shine a flashlight up there to see if it is completely drained ?
08-10-2016, 10:33 AM
that's how I do it was well with our TT, I use the leveling blocks with my 3' level on the back bumper. I then pull onto or back onto the blocks. Then drop it, grab a drink and have a good time
2013 Prime Time Tracer 3200BHT
2016 Chevy 3500 CC, DRW (aka: bigbootyjudy)
Ribs in the smoker and Whiskey in hand
08-10-2016, 10:52 AM
Don't think you'd want to shine a flashlight up there. You never know what could drip out. Get a clear sewer elbow (link below) with a back flush adapter. When the water running out is clear you're good. Then dump grey tank to flush out the sewer hose.
link: https://www.amazon.com/Valterra-F02-.../dp/B0002UHVAA
Pulling onto 2x6's, leveling blocks or whatever is a common, accepted method of leveling side to side. Once you acquire a selection of levelers, it only take a few seconds to level up before unhitching. No need to use bottle jacks or climb under the camper.
Unless your black tank has a built in flush feature about all you can do is be sure it is almost full when dumping to evacuate the waste out of the tank. Depending on how your toilet is plumbed to the black tank, you might be able to get a flush wand down through the toilet and flush that way as well.
08-10-2016, 11:26 AM
We use Anderson Levelers. They work great.
3604 - Camper Leveler
Available on Amazon.
Here's a YouTube video on them.
anderson levelers - Bing video
Mike & Angela
Gunny & Marley
2009 Ford F-250 SD 4x4
2017 Rockwood Roo 233S
08-10-2016, 11:37 AM
Not that they don't have their own limitations, but check out the Andersen Leveler. They are very popular with members here (including myself). My guess is that with your smallish trailer you will have to modify them a little as explained in the thread linked below (due to limited space between your axles)...
http://www.forestriverforums.com/for...ers-43295.html
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2021 Solitude 310GK w/FBP
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
08-10-2016, 11:53 AM
Another vote for Andersen levelers.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2021: 35 nights already booked so far
08-10-2016, 12:02 PM
Are there any issues with Anderson levelers breaking? I've read some reviews where the plastic levelers like them break.
Ron & Ann
2016 Wildwood Heritage Glen 282RK
2015 Silverado 1500 5.3 355hp 3.42 rear gears
08-10-2016, 12:05 PM
The very few instances where I read about the levelers breaking, Andersen replaced it for free. I have not had an issue in three years of regular use on a TT like yours.
Lee and Anne
08-10-2016, 12:06 PM
I've been camping for 50+ years - starting as a kid of course - before Anderson Levelers were popular. I and my dad before me have used a wedge we built for leveling and used a level bubble mounted on the trailer. I've always found that to be quick and easy. The wedge can be a lot smaller for a single axle unit, but it works for both. I carry an 18" long x 6" high wedge made out of 5/4" x 6" pressure treated deck wood and a plastic chock for my current single axle unit.
I use Anderson Levelers with an 8,000 lb trailer with no issues. Never broken one. Read and follow the instructions and you shouldn't have any issues.
Jack and Jan
Nights camped 2014 - 8 | Nights camped 2015 - 23 | Nights camped 2016 - 24
2015 Ford Super Duty F350 > Blue Ox Swaypro WD Hitch > 2015 Rockwood Windjammer 3008W
08-10-2016, 12:18 PM
It is what we use as well. A lot cheaper than 40 + dollars a pop per wheel. I would not feel real comfortable just using on a dual wheel set up.
Chuck & Denise + Pata, The Purple Princess Peanut, Ziggy the pole cat and Kazumba the parrot
2015 23 BD Gray Wolf
2008 Dodge Ram 2500 TX Edition 2015 - 7 nights, 2 trips, 2016 - 2 trip, 24 nights, 2017 1 trip, 3 nights 2018 1 trip, 93 nights
08-10-2016, 12:19 PM
Leveler blocks (Legos) and a 4' level. Done.
08-10-2016, 12:20 PM
camper leveler $80 + tax and shipping
2 x 6 cut into short pieces $5.
i also cary two short 1 x 6s. after a few times camping you can pretty much judge how high the RV needs to go by the level's bubble. I would also suggest you use the floor in your RV to level it, not your bumper as the two may not be the same.
08-10-2016, 12:42 PM
Although the Anderson levelers are really great lego blocks, 2X6, or what have you are far cheaper. After leveling a few times you'll get the hang of it and it becomes real quick. We put a 2 foot level inside the door of our 5th wheel and take a look at the bubble, can never depend on the back bumper but could work for you, judging the bubble on the level determines how many lego blocks or 2X6's we'll need, after a few times you'll get the hang of it and be pretty close most of the time. After leveling if the bubble is within the lines of the level but not exactly in the middle don't sweat the small stuff, pull a chair out and enjoy the outdoors.
08-10-2016, 02:15 PM
I have a set of Anderson Levels to sell for 60.00 Plus freight!
If you want them contact me.
Regards
Wayne
Wayne and Gayle Wilson
2016 F-150 3.5 Eco Boost Max Tow Package
2014 Flagstaff Classic Super Lite 8528RKWS
08-10-2016, 02:26 PM
Depending on the weight of your trailer, you could use this:
BAL - Innovative Products for the RV Industry
I used this, when I had a PopUp. It is rated at 1750lbs (total trailer weight of 3500lbs). They are fairly easy, don't take up a lot of room and can replace a stack of blocks and a set of chocks.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2016 Ram 3500 Laramie 4X4 6.7 Cummins Diesel
Never Enough Time Camping!!
08-10-2016, 02:38 PM
Been using Lynx levelers for 10 years now with no issues.
08-10-2016, 03:05 PM
Levelling blocks and a 2 foot level on the counter. Easy as pie, but it may take a few tries to get the correct height. Then a glass of wine, red.
08-10-2016, 03:25 PM
I would check the level in the fridge. The floor and fridge in mine don't match about a quaternary to half bubble difference between the two, and it's the fridge that really needs to be level.
I use 2x8 about 5 foot long on mine with a wedge made out of a block of oak foot long 8 in high. Overkill I guess
