Old 01-23-2015, 12:28 PM   #11
Mikegjax's Avatar
Here is a link to an antenna pointing app for a smartphone. After installing I did need to restart the phone for it to work.
https://play.google.com/store/apps/d...per.free&hl=en
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 01-23-2015, 02:04 PM   #12
AquaMan's Avatar
I have a signal meter that simply plugs inline and gives signal strength in LEDs. The problem with these types of signal indicators, is that if there is a cell tower nearby, it will interfere and give a false reading.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 01-23-2015, 04:27 PM   #13
BeagleIL's Avatar
I have the Winegard Amp mentioned above. Sure you can use your smartphone or tablet to find out where the antennas are. But I can easily dial in the best direction just by looking at the meter which is on the wall right next to where I stand to turn the antenna. I turn the antenna until I see the highest read out and then set the TV to perform an auto-tune. A few minutes later the stations are ready to watch.
Mark, Jenny, Adam & Lucy
2013 Rockwood Roo 233S
2015.5 Silverado 2500HD CCSB with Duramax/Allison
BeagleIL is offline   Reply With Quote
Old 01-23-2015, 06:30 PM   #14
urocav2001's Avatar
Signal meter
Where do I find the type that plugs in line
urocav2001 is offline   Reply With Quote
Old 01-23-2015, 09:02 PM   #15
DK-in-SC's Avatar
Can't help with the plug in type. I use an app for my iPhone called TV Towers USA. It uses the GPS on the phone and shows a map of the stations in the area. There is an arrow that points on the map and you rotate your phone to point to the stations. Then just line up the RV's antenna with the arrow and you are all set. Works great.
I live with fear every day, and sometimes she lets me go fishing.
2015 Shamrock 23IKSS
2008 Ford Expedition EL
DH-DW-D3K-DMTTSAP
DK-in-SC is offline   Reply With Quote
Old 01-24-2015, 06:48 AM   #16
We use TV Towers USA also.
Glen & Lee
Dawsonville, GA
2013 V-Cross Platinum 325VRL
2017 Ford F350 PSD
GlenZ is offline   Reply With Quote
