Old 04-16-2014, 08:47 AM   #21
Witch Doctor's Avatar
I wouldn't worry to much about a tp holder. When we did our walk through the tp holder was not installed. So the salesman called a worker over. He told him to install it. So the guy asked my wife where do you want it. She said so it's not in the way. The next thing I see is this guy sitting on the head. He was reaching his hand out and stuff. At the end he asked my wife and said how about here. He then showed her it was in reach and out of the way. She said fine. He just screwed it into the wall. No anchors or nothing, been there for over 2 years without any problems. True Story @ the FR dealer.....
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 04-16-2014, 08:54 AM   #22
hihocarp's Avatar
In my old 5th wheel I made a board out of mdf,painted it white and the used PL Premium to attach it to the wall holding it in place with masking tape till the glue dried and then mounted the TP holder to that. Hasn't come off in 11 years of use. If I have to mount the holder in our Columbus ( will be picking it up April 21st ) I'll b using metal butterfly anchors.
2012 Dodge Ram 3500 Crew Cab Dually
2015 Columbus 365 RL ( completed April 14,2014 )
Baxter and Bella [our dogs]
Days camped in 2014: 7
hihocarp is offline   Reply With Quote
Old 04-17-2014, 06:37 PM   #23
Resident Masshole
force's Avatar
Originally Posted by DEBailey View Post
As you see I'm up at 2 am bc I'm worried about my paper towel install. I used small ( maybe 1/2 in screws) and installed mine under the microwave on my 2014 233s. It appears there was
Enough "wood" under the microwave but now worried it was molding I was and that maybe the microwave sits lower in the space then I thought. When I screwed in it did not sound to me like the screws hit metal/the microwave but I'm worried maybe they did and damaged it! Should I be?
I just had my microwave out to install a 12v LED light over the sink. The microwave actually sits a full inch above the cabinet bottom on a separate piece of wood, so you can sleep soundly.
Tom F.
2013 GMC 2500HD SLT Crew Cab
2013 Rockwood Roo 23SS
Nights camped in 2014: 8
Nights camped in 2013: 30
force is offline   Reply With Quote
Old 04-17-2014, 09:05 PM   #24
Ah what a relief! Thanks
DEBailey is offline   Reply With Quote
Old 04-17-2014, 09:26 PM   #25
10x
Originally Posted by rsmobley85 View Post
We were scared to drill holes in our new TT as well, But after the first, it was nothing for the rest. LOL!
We used pop toggles that are made for thin drywall, they hold 50lbs. Not sure, I need that much, but they work great for the TT walls, We used them for the TP holder, hand towel holder and we hung a hanging shoe holder on the back bathroom wall to hold everything. And it holes it up just fine with everything in there.
You have to drill a hole, use a drill stop so you dont go though the wall. Then fold it so its bent in half in the center, insert in the hole, use the popping pin that comes with it, then screw in your TP holder.
Where did you buy these?
2014 XLR 27 HFS
2010 F250 4x4 Crewcab Turbo Diesel
10x is offline   Reply With Quote
Old 04-17-2014, 09:35 PM   #26
Boss Ox & Drovergirl
oxcamper's Avatar
For towels, try the 3M Command hooks. They work great. The bigger ones hold up to 5 lbs., more than enough for wet bath towels. The added benefit is they can come off easily, they're reusable, and no holes in the wall.
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2010 F250 Super Duty
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 04-17-2014, 09:54 PM   #27
BamaBob's Avatar
Originally Posted by BadgerRoo View Post
Ok thanks! Wallboards good for the generic towel holder they supplied as well?
As an alternative, consider a over the bathroom door towel rack. It's what we use and we love it!
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
BamaBob is offline   Reply With Quote
Old 04-17-2014, 09:58 PM   #28
BamaBob's Avatar
Should be able to get them at Home Depot
Old 04-17-2014, 11:00 PM   #29
phat phrog stunt crew
We too have a floor stand tp holder. It can be moved to accomadate left and right handed folks by simply moving. When traveling, a simple rubber band keeps the roll rolled up. And laying the stand over before leaving keeps it pretty much where you left it. Plus, it also lessens the stress about what exactly is behind where you're planning on drilling.
Sent from ny nook using fairly accurate digits.
dwaynerz is offline   Reply With Quote
Old 04-20-2014, 09:40 PM   #30
I did what brother les did. I screwed it to the inside door of the bathroom cabinet. I leveled and centered the TP holder then used a small drill bit with a little tape on the bit to reference depth of the screw, then applied the screws. Worked well. Didn't bother with the towel rack added upper door hangers for towel racks. With two small boys, it's gonna rip out of the wall!
jnbwest97 is offline   Reply With Quote
mount
