Old 06-13-2015, 02:34 PM   #1
skylight has a small crack
have a Shamrock m233 unit with a skylight in the bathroom. discovered a small crack in the outer unit (unit on the roof) where the flange transitions into the bubble. What would be a good caulk to seal this up?
tdehoff is offline   Reply With Quote
Old 06-13-2015, 02:38 PM   #2
Ford Idaho's Avatar
For a temporary fix I'd use this.
EternaBond RoofSeal WHITE Repair Tape, 4 in. x 50 ft. Roll
Long term order a new skylight.
Old 06-13-2015, 07:13 PM   #3
Marines0811's Avatar
FYI I found a small roll on the Walmart website of Externabond was a lot cheaper than the larger rolls if you only need a little.
Marines0811 is offline   Reply With Quote
Old 06-15-2015, 07:20 AM   #4
Hicks43's Avatar
^^ wal mart has a small repair kit in with the camping stuff. I picked one up just to have
Sent from my iPhone using Forest River Forums 2015 21ss havein fun
Hicks43 is offline   Reply With Quote
Old 06-15-2015, 01:14 PM   #5
Stop drill first
Stop drill the crack first... 1/8 in from where you see it end... to prevent it from cracking further. Best fix is to replace it
Mewcasa is offline   Reply With Quote
Old 06-15-2015, 01:58 PM   #6
DDC
DDC's Avatar
There was a recall on some of these, mine was replaced in the recall and replaced again in Goshen last year it is ok so far.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 06-15-2015, 05:15 PM   #7
About that crack...
I did not fix soon enough or well enough so I got a new roof, wow did that cost.I did learn lesson do it right the first time its a lot cheaper.
Bobster
2013 ROCKWOOD 8289WS
2013 Silverado 2500HD Crew/Longbed
rshultz is offline   Reply With Quote
Old 06-15-2015, 05:33 PM   #8
Cyber Phrenologist
Radio's Avatar
Here is my adventure in changing the shower skylight bubble. I wrote it up as a tutorial.
I liked my supplier and the quality of the new tinted bubble, also the fact it CAME WITH the proper sealant.
D-I-Y Shower Skylight Bubble Change
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 06-15-2015, 06:09 PM   #9
I second the suggestion. Stop drill with a 1/16" bit at the tip of the crack. 1/8" will work but is overkill. You can fill the hole with superglue gel.
MartyQ is offline   Reply With Quote
Old 06-16-2015, 07:33 AM   #10
My fault that I neglected to state what size drill bit to use... Yes 1/8 would be overkill... Should have stated "use #40 plexiglass (or equivalent) drill bit 1/8 in from the crack progression..."
I was always a believer that "Size does matter!" (Sorry, couldn't help myself)
2016 Vibe 268RKS
2015 Chev 2500HD
light
