Old 11-11-2011, 07:03 AM   #11
Fire Instructor's Avatar
Originally Posted by f1100turbo View Post
my sticker on my 2011 says must be hooked to shore power to move slides .
So how could/do you camp somewhere without shore power? It would make it awful tough to boondock, if you need shore power just to move the slides.
BTW - When we were looking at TT's (to purchase) a few years ago, it was between Thanksgiving and end of year, so most units in the dealerships outside lots had already been winterized, with slides closed. In more than one dealership, since they don't leave batteries in the units on the lot, the salesmen carried those small 12v jumper boxes, designed to give a car a quick jump start. This is what they used to move the slide in and out and "show" the unit without a battery or shore power.
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 11-11-2011, 07:31 AM   #12
Herk7769's Avatar
Fire Guy, I think you missed his point. It is not shore power that has to be connected but the battery. That "jumper box" takes the place of the battery. I am sure it is plugged in between demos, since it has to pull that baby flat opening and closing the slides. The AH rating has to be no more than 5 or 10. (100 - 200 total amps available). At that high a discharge rate compared to AH rating, the true capacity may only be 50% of rated.
Name:	battery voltage and capacity Curve vs Discharge Rate.jpg
HAM CALLSIGN - KC3FFW
Old 11-11-2011, 08:52 AM   #13
acadianbob's Avatar
I move my slide without the battery all the time. No issues.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 11-11-2011, 09:57 AM   #14
Triguy's Avatar
Originally Posted by herk7769 View Post
They say the unit in my camper is rated for 55 amps DC so it should be capable of doing both at the same time, but I don't feel like buying a new one just to find out..
Herk, welcome back!
I've got a stupid question. My WFCO puts out 55 amps and I believe my slide motor is a 30amp. While moving the slideout, if I were also running other items in the trailer (AC, lights, etc) that would draw more current than the WFCO can provide to all of these items, then wouldn't it just pup a fuse or circuit breaker?
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 11-11-2011, 10:59 AM   #15
Herk7769's Avatar
Originally Posted by Triguy View Post
Herk, welcome back!
I've got a stupid question. My WFCO puts out 55 amps and I believe my slide motor is a 30amp. While moving the slide out, if I were also running other items in the trailer (AC, lights, etc) that would draw more current than the WFCO can provide to all of these items, then wouldn't it just pup a fuse or circuit breaker?
Are we talking about with the battery removed? If so, I guess it would depend on how the total load on the DC side is protected (unknown since it would be internal to the WFCO) and there is no circuit diagram provided.
There are two 40 amp reverse current fuses (so that is not the protection); it is on the same 120 VAC circuit breaker (in my camper) as the living room and kitchen GFCI circuits (so that is not the protection); and the 12 VDC fuses are all 15 amp in the box (so that is not the protection) and there are two 30 amp Slide fuses and a 30 amp landing gear fuse hung off the battery buss (at the battery), so THOSE are not the 55 amp protection.
Since 12VDC x 55 amps is 660 watts, we are only talking about 5.5 amps AC at full DC draw. This is well UNDER the 15 amp 120 VAC circuit breaker it is hooked to.
Long and the short of it? I don't know if there IS any overload protection for the 55 amp DC side other than overheating or component failure without a circuit diagram.
Old 11-11-2011, 11:33 AM   #16
Triguy's Avatar
This is good. I pulled up the installation manual and the wiring diagram is not clear (at least to me). I attached it in case anyone is interested.
Interestingly, when I read through it, I found a general feature notation that states "...Automatically shuts down power during overload or short-circuit conditions.
Automatically returns to normal operation after conditions are corrected."
It didn't go into details, however.
Scott
2012 Shamrock 233S
Old 11-11-2011, 12:03 PM   #17
TURBS's Avatar
We have a 7000 watt generator!
And where I live there isn't any parks that don't have power.
We boondock with friends twice a year in a big private timber and we all have gennies.
Old 11-11-2011, 12:07 PM   #18
Herk7769's Avatar
Interestingly, when I read through it, I found a general feature notation that states "...Automatically shuts down power during overload or short-circuit conditions. Automatically returns to normal operation after conditions are corrected." It didn't go into details, however.
Thanks for adding that. I was looking at the "diagrams" not the text when I added my comments. The manual has "hook up" drawings and not actual circuit board schematics.
battery
