Old 09-05-2015, 02:04 PM   #11
I have a 2015.5 23ss. Came with then but they never told me about them. When I found them I have been using them but even with the orange tags 2 times now I've almost opened the slide without removing g the locks. Both times it was late at night setting up. I just keep having a vision of the trim braking or a hole in the wall. I guess same fear as driving away with the tv antenna up.
1st timer is offline   Reply With Quote
Old 09-05-2015, 04:38 PM   #12
We got them with ours & used them until one time my wife cranked them too tight & popped the decorative face over the slide off. Took my brad nailer & popped it back into place. Can't even tell it was ever popped out. Since then we haven't used them & can't say that we have missed them. Probably why they aren't used much now. Too much damage from over tightening them or forgetting to remove them & then trying to open slide with them in place and causing damage that way.
2001 Chevy Silverado
2011 Rockwood Roo 233S
rbq is online now   Reply With Quote
Old 09-05-2015, 06:33 PM   #13
Kaadk's Avatar
We have them on our 29QBSS and I use them all the time. The only time I don't install them is the short drive (<5 kms) between house and storage lot.
Never had a problem with them once. As long as you use them all the time, you get used to remembering about them.
My biggest fear for them is at the border. Haven't had an issue yet, but in the back of my mind I'm just waiting for the one border guard who decides to put the slide out without seeing the tags and asking me to remove them first.
There's no use crying over spilled milk, unless it's on your keyboard.
Old 09-06-2015, 10:47 PM   #14
kennyairport's Avatar
we have them and the tech during walk thru indicated that he has fixed many slides that were opened with them in place but never fixed a slide that came out with them not being used.
ken and denise
2015 shamrock23ss
2015 Ram Eco diesel
previous 1997 coleman highlander pup,1994 35rb Vectra
diesel,2007 Fleetwood arcadia pup.
2005 ram
kennyairport is offline   Reply With Quote
Old 09-08-2015, 06:43 AM   #15
Dave Lyon's Avatar
Originally Posted by bikendan View Post
Ours came with orange tags hanging from them.
so you can't miss them.
X2........and I always use them. Forest River provided them for a reason.
Dave, Southern,ON
2009 GMC K1500 4x4 Crew Cab
2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
Old 09-08-2015, 06:55 AM   #16
Herk7769's Avatar
Another "Always Use Them" for my main slides.
Lippert electric rack slideouts can be broken loose in a turn and open if the motor/gearing clutch gets worn. That clutch is designed to let the motor slip when the slideout is fully open or closed (you can sometimes hear it).
A rough road or railroad track crossing can walk that slide right out unless it is locked in place.
I do not use the one (I made) for the NORCO (wire sprung) wardrobe slideout because that one is only used when the motor/gear assembly fails and needs to be removed to close an open slide for travel to repair it.
Name:	Roof Shots and others 025.jpg
ID:	88106   Click image for larger version
Name:	Camper Slide Braces 005.jpg
ID:	88107   Click image for larger version
Name:	Camper Slide Braces 003.jpg
Old 09-08-2015, 07:26 AM   #17
Filthy Beast's Avatar
When we had them with our first trailer we used them every time. I believe they were supplied for a reason.
Goody Two Shoes and the Filthy Beast
2008 Chevy Silverado 2500HD
Duramax and Allison 6 speed
2012 Wildcat 282RKX
You can't make things idiot proof, you can only make them idiot resistant.
Filthy Beast is offline   Reply With Quote
slide, lock
