Old 10-09-2013, 06:22 PM   #1
urocav2001's Avatar
Slide out fuse
Can someone tell me where the slide out fuse is located and what size it should be? I am going to pick up a few extras, I know I've read somewhere on here people having trouble with them and I cringe every time I open/close it. Thanks
2013 shamrock 233s
urocav2001 is offline   Reply With Quote
Old 10-09-2013, 06:43 PM   #2
dretired's Avatar
Probably located near the battery ....30 amp...green in color...i had a issue of my fuse blowing if the rocker switch for the slide out was depressed too long or the electric jacks also
2014 Crusader 325 TE....2012.. F 250.. Supercab XLT, 4x2 , diesel....days camped 2011 ... 28.... days camped 2012...115 ... days camped 2013...155...2014...171 and counting
dretired is offline   Reply With Quote
Old 10-09-2013, 08:53 PM   #3
Triguy's Avatar
As dretired says... Its a 30 amp a few feet back from the front of the trailer (street side).
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 10-09-2013, 09:07 PM   #4
TURBS's Avatar
I'd recomend replacing it with a self resetting circuit breaker such as this and of the same amperage.
Turbs
Old 10-09-2013, 09:09 PM   #5
TURBS's Avatar
Slideout fuse may also be located in here.
I'd still recommend replacing it with a self resetting circuit breaker.
Turbs
Old 10-09-2013, 09:09 PM   #6
GlacierGus's Avatar
Turbs -where would you get breaker like that? Thanks.
2013 Rockwood Mini Lite 2109S
2006 Dodge Durango Hemi 5.7
Equal-i-zer WDH
GlacierGus is offline   Reply With Quote
Old 10-09-2013, 09:14 PM   #7
TURBS's Avatar
Any automotive parts store such as napa, O'Reillys, car quest or autozone.
Get the extended tang version such as I've pictured if you need to put them in your distribution center.
You can always shorten the tangs if needed as there pre scored.
Turbs
Old 10-10-2013, 04:37 AM   #8
urocav2001's Avatar
Sweet thanks never thought about a circuit breaker... Anyone know why the fuse blows anyways
Old 10-10-2013, 11:12 AM   #9
bikendan's Avatar
often owners push the toggle switch too long, either to close or open, and the fuse blows before the gears get broken.
the second you hear the motor/gear chatter, you gotta let go!
sometimes it's the kids fooling with it, without parents' knowledge.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 10-10-2013, 11:48 AM   #10
urocav2001's Avatar
Ok thanks It makes perfect sence now
expandable, hybrid, shamrock
