Old 06-28-2016, 07:53 PM   #21
Celestep2k1's Avatar
Best reason, period.
Originally Posted by bareftn View Post
They are their for a reason and its called SAFTEY EQUEPMENT use them ( it only takes a minute to put them in) for if you don't and for any reason what so ever the slide comes out and cause a accident or comes out from a accident guess who will be held liable and maybe involved in a lawsuit?
Most sage advice!
Thank you!
Celestep2k1 is offline   Reply With Quote
Old 06-28-2016, 07:58 PM   #22
Originally Posted by wmburdette View Post
I have problems getting them to seat properly against the back side of the facia board with the rubber/vinyl seal. If I crank them down tight enough to stay put with road movement I worry that I may be harming the seal and/or the facia. Any thoughts from others?
'07 Roo 23SS
After using them the last 140-miles and two set-up/tear-downs, I can see that their point isn't to be too tight, but to simply be there to stop the slide top from moving. Now that I look at it, they are the only thing that ensures the top is secured.
Happy, and safe, camping!
Old 06-28-2016, 08:09 PM   #23
Old Eeyore's Avatar
I applied heavy duty Velcro to the wall and one pad. That helped me get that far end in place - and to keep it there while I snugged it up.
There were lots of warnings about over-tightening. The bars are just supposed to keep the slide from moving - so they only need to be tight enough to keep them in place.
2016 Roo 23IKSS / 2011 Tahoe
2011 Roo 21SS / 2011 Tahoe
2006 Bayside / 2006 4Runner
1999 SantaFe / 2001 Sienna
1967 Nimrod / 1998 Outback
Old Eeyore is offline   Reply With Quote
Old 06-28-2016, 08:27 PM   #24
Canadian Member
itat's Avatar
Bareftn and Celestep2k1, I'd suggest that the risk that the slide would actually fall out of the trailer from the closed position is absolutely minuscule. I've never heard of it actually happening. If you have an example please post a link to the story.
The real risk is that the slide would move enough to go out of alignment and not seal properly. Not good, but not catastrophic.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 06-29-2016, 06:58 AM   #25
Wolverine 1945's Avatar
As I said we always put ours in our old TT,,, but no matter how tight I got them,,, after about 300 miles on out Great Hwys,,, they always fell out !!!
Wouldn't it be better if the slides had safety locks on the outside ???
Wolverine 1945 is offline   Reply With Quote
Old 06-29-2016, 11:10 AM   #26
Canadian Member
itat's Avatar
Having the locks on the inside the way they are designed relies on the structural integrity of the complete wall system above the hole for the slide whereas a locking mechanism on the outside would rely on the ability of its fasteners to not come out of the wall.
If you're concerned about the possibility of the rectangular pads on the locks cutting the seals on the back of the fascia board you could round the edges a bit so the don't have a sharp edge.
I like the idea of Velcro on the white stickers to hold the pad in place while you tighten the locks. Other than having to stand on a stool to get high enough, that's the only difficulty I have when installing my locks.
Old 06-30-2016, 07:24 AM   #27
I believe if properly designed,,, Out Side Locks would be the way to go !!!
Old 06-30-2016, 02:31 PM   #28
Timex's Avatar
All good inventions were started with that phrase.
Let us know what you come up with!
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
Old 06-30-2016, 07:08 PM   #29
hmm, my '17 21ss didnt come with any or any stickers
'17 Flagstaff Shamrock 21ss
'13 Grand Cherokee-5.7
JeepGuy is offline   Reply With Quote
Old 07-01-2016, 12:23 AM   #30
Old Eeyore's Avatar
My '11 21SS came with them. My '16 23IKSS didn't. The large slides are virtually identical. (Size, shape and mechanically.)
Generally I take the position that if the manufacturer supplied them then I probably ought to use them and I used them the first year. Got tired of the gyrations to get my arm in - and then back out. Took a few trips the second year without them and saw no difference and threw them up in the front shelf - just in case - and there they stayed waiting for the next owner.
slide, slide out
