06-28-2016, 07:53 PM
#21
Best reason, period.
Originally Posted by bareftn
They are their for a reason and its called SAFTEY EQUEPMENT use them ( it only takes a minute to put them in) for if you don't and for any reason what so ever the slide comes out and cause a accident or comes out from a accident guess who will be held liable and maybe involved in a lawsuit?
Most sage advice!
Thank you!
06-28-2016, 07:58 PM
#22
Originally Posted by wmburdette
I have problems getting them to seat properly against the back side of the facia board with the rubber/vinyl seal. If I crank them down tight enough to stay put with road movement I worry that I may be harming the seal and/or the facia. Any thoughts from others?
'07 Roo 23SS
After using them the last 140-miles and two set-up/tear-downs, I can see that their point isn't to be too tight, but to simply be there to stop the slide top from moving. Now that I look at it, they are the only thing that ensures the top is secured.
Happy, and safe, camping!
06-28-2016, 08:09 PM
#23
I applied heavy duty Velcro to the wall and one pad. That helped me get that far end in place - and to keep it there while I snugged it up.
There were lots of warnings about over-tightening. The bars are just supposed to keep the slide from moving - so they only need to be tight enough to keep them in place.
2022 Rockwood 2608BS / 2019 Silverado 1500
2016 Rockwood Roo 23IKSS / 2019 Silverado 1500
2011 Rockwood Roo 21SS / 2011 Tahoe
2006 Fleetwood Bayside / 2006 4Runner
1999 Coleman SantaFe / 2001 Sienna
1967 Nimrod / 1998 Outback
06-28-2016, 08:27 PM
#24
Canadian Member
Bareftn and Celestep2k1, I'd suggest that the risk that the slide would actually fall out of the trailer from the closed position is absolutely minuscule. I've never heard of it actually happening. If you have an example please post a link to the story.
The real risk is that the slide would move enough to go out of alignment and not seal properly. Not good, but not catastrophic.
06-29-2016, 06:58 AM
#25
As I said we always put ours in our old TT,,, but no matter how tight I got them,,, after about 300 miles on out Great Hwys,,, they always fell out !!!
Wouldn't it be better if the slides had safety locks on the outside ???
06-29-2016, 11:10 AM
#26
Canadian Member
Having the locks on the inside the way they are designed relies on the structural integrity of the complete wall system above the hole for the slide whereas a locking mechanism on the outside would rely on the ability of its fasteners to not come out of the wall.
If you're concerned about the possibility of the rectangular pads on the locks cutting the seals on the back of the fascia board you could round the edges a bit so the don't have a sharp edge.
I like the idea of Velcro on the white stickers to hold the pad in place while you tighten the locks. Other than having to stand on a stool to get high enough, that's the only difficulty I have when installing my locks.
06-30-2016, 07:24 AM
#27
I believe if properly designed,,, Out Side Locks would be the way to go !!!
06-30-2016, 02:31 PM
#28
All good inventions were started with that phrase.
Let us know what you come up with!
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
06-30-2016, 07:08 PM
#29
hmm, my '17 21ss didnt come with any or any stickers
'17 Flagstaff Shamrock 21ss
'13 Grand Cherokee-5.7
07-01-2016, 12:23 AM
#30
My '11 21SS came with them. My '16 23IKSS didn't. The large slides are virtually identical. (Size, shape and mechanically.)
Generally I take the position that if the manufacturer supplied them then I probably ought to use them and I used them the first year. Got tired of the gyrations to get my arm in - and then back out. Took a few trips the second year without them and saw no difference and threw them up in the front shelf - just in case - and there they stayed waiting for the next owner.
07-01-2016, 04:25 AM
#31
Their are lots of things that happen and you don't hear of it, Lots of different things in life have safety equipment and you never hear of what it did prevent or if anything did happen because safety equipment was not used. If locks are given and a place to install then I am going to use them. What your saying is pure bull gee I never had a fire in my house so why should I have smoke detectors in it? what your saying may let someone think well he is right so I am not going to use mine and then something happens,so if you choose to not use them so be it
07-03-2016, 12:01 PM
#32
On our 08 Roo 21SS there were stickers on the outside wall to show where the travel locks should be positioned. On the edge of the fascia where the seal was there were indentations where the locks were positioned. These roughly corresponded to the stickers on the outer wall. We always used ours because of how heavy the slide is. You have to feel with your hand where the indentation is.
Mike
07-04-2016, 12:39 PM
#33
We used them this last trip and glad to say they never came out. Stayed in place with no problem. The string with the little orange warning signs are there for a reason. Do not cut them off the bar and make sure to hang them over the top of the slide. That way you won't forget their there. Almost forgot ours and started to open the slide, but realized they were on and stopped in time not to cause any damage.
If you go with the flow, you miss too much.
Randy Pugh
Cadillac Escalade
Rockwood Roo 21SS
Moses Lake WA.
07-05-2016, 06:11 AM
#34
Very Good Info on the tags !!!
07-05-2016, 07:05 AM
#35
Awhile back someone suggested laminating the orange tags on them to help 'em last longer. Not a bad idea...
2019 Coachmen Freedom Express 281RLDSLE
2018 2500 HD Silverado
Equal-i-zer Hitch E4
07-05-2016, 07:08 AM
#36
Right On !!!
07-05-2016, 03:46 PM
#37
Put a little hook screw above the slideout button and loop the tag in the hook. The slide won't be opened unless the button is pressed, right?. You'll see the tag before you "accidentally" forget about the slide locks.
07-05-2016, 03:58 PM
#38
Using the slide locks will (should) keep the top of slide in when travelling on rough roads or during unforeseen events.....
Fonzie
07-06-2016, 01:18 PM
#39
That is a good idea too. Energy lockout so to speak. Good for the ones who don't have the tags still.
Randy Pugh
Cadillac Escalade
Rockwood Roo 21SS
Moses Lake WA.
