Old 06-30-2015, 08:42 PM   #1
Slides leak from underneath
Have the new 23IKSS out on its first long trip - Yellowstone bound - and have driven through rain for a couple of days. The floor is wet in the kitchen and also the carpet on the dinette couch slide. Obvious it is coming from road spray off the tires. Has anyone experienced this? I figure it will get into the dealer when I get home in. A couple of weeks. All else is going great. Tows like a dream behind my F150.
2015 Roo 23IKSS
2016 F150 SuperCrew 3.5 EcoBoost
Kanga99 is offline   Reply With Quote
Old 06-30-2015, 08:50 PM   #2
Hicks43's Avatar
21ss never had road water come in.
Sent from my iPhone using Forest River Forums 2015 21ss havein fun
Hicks43 is offline   Reply With Quote
Old 07-01-2015, 02:21 PM   #3
Georgia Frog Rally 2018
aceinspp's Avatar
They may have forgot to put the seals in and around the slides on the bottom. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 07-01-2015, 02:40 PM   #4
Yellowstone is on our list this summer as well. Sorry to hear about the leak. We took our 2016 233s out a couple of times far this past month and it rained so hard. I did have water on the front bunk ledge that ran down the floor to the front of the slide. I attributed it to the top outside seal on the front bunk.
Is it on one particular side of the slide out or near a bunk?
2014 Toyota Tundra Double Cab 4x4
2016 Rockwood Roo 233s
Blue Ox WDS Hitch
P3 Brake Controller
Timbren Suspension
teamtlr is offline   Reply With Quote
Old 07-01-2015, 05:23 PM   #5
Water
Check the tire well,a few years ago,I had a tire blow out and didn't notice that it had damaged the tire well until I went through a heavy rain,there was water all over the floor under the couch,the tire blow out did lots of damage to the well.
Bearhugger1933 is offline   Reply With Quote
Old 07-01-2015, 05:35 PM   #6
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
I have the exact problem. It looks like the slide is not closing completely on the front lower section of the curb side slide. I have a work request in for the service group to look at it at the FROG rally in August.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 07-01-2015, 06:27 PM   #7
Rivnut
Rivnut's Avatar
same problem with Aviator
Rivnut is offline   Reply With Quote
Old 07-01-2015, 07:05 PM   #8
Bet the bottom sweep seal is not there or not up against the bottom of the slide. It's something we see a lot. You should have a seal similar to the ones on the sides that lean against the slide and act like a squeegee. And also a seal when fully closed. If the slide is over the wheels it is critical that this is tight. There is a lot of pressured spray in that area.
hillsdaletc is offline   Reply With Quote
Old 07-01-2015, 07:06 PM   #9
wheel splash causing wetness on floor
yes i had that on 36 CKTS ,the cord , hoses, etc on the slide hindge were up too high and laying on the rubber seal letting wheel phlash wet the carpet ,check the forems for other posts on this goog luck
Big Bill is offline   Reply With Quote
Old 07-05-2015, 12:00 PM   #10
Rivnut
Rivnut's Avatar
water leaks under slide
I see no sweep installed, will try to make one until I get to Rally. thanks guys
leak, slide, slide out
