Old 04-08-2015, 09:27 PM   #11
fedrocker's Avatar
It turned out to be the hot water connection under my sink - hand tightened - seemed to do the trick.
I am going to check the low point soon. Where is that btw ?
fedrocker is offline   Reply With Quote
Old 04-09-2015, 12:00 PM   #12
fedrocker's Avatar
For the low point drains - what am I looking for exactly?
2011 Rockwood Roo 233s
2007 Tundra Crewmax, 5.7
Old 04-09-2015, 12:34 PM   #13
Originally Posted by Eric F. View Post
If there is a shower building I would use it. The water is leaking down to the plywood and may be saturating it. I pulled the panel from below the bathroom sink and pointed my space heater into it to help dry it out. I'm paranoid that way.
Very good advice EricF, RV owners must Take Notice!! There is NO such thing as a (Small Leak) in a RV! A leak can cause $$$$$ in a Short period of time! Youroo!!
Old 04-09-2015, 12:34 PM   #14
bob213's Avatar
Usually one blue and one white pex pipe hanging under unit with caps on the ends.. Could be on both sides.
You can avoid reality, but you cannot avoid the consequences of avoiding reality Ė Ayn Rand
bob213 is offline   Reply With Quote
Old 04-09-2015, 12:48 PM   #15
fedrocker's Avatar
The low end points are not leaking.
Old 04-09-2015, 01:06 PM   #16
fedrocker's Avatar
Looked under bathroom sink - there are just no leaks there or close by - couldn't remove wall abutting the shower - maybe I misunderstood the earlier advice
Old 04-09-2015, 06:50 PM   #17
Mine are blue (cold) and red (hot).
2011 Traverse LT, 3.6L, FWD
Old 04-09-2015, 07:24 PM   #18
fedrocker's Avatar
Mine are the same color. On the door side.
Old 04-09-2015, 11:13 PM   #19
Eric F.'s Avatar
If you look under the bathroom sink the panel that blocks off the back part is attached to a small piece of one inch by one inch wood with two screws going into the floor. Take those out and that whole flimsy panel will come out.
When I took out mine I could clearly see the water coming out from below my shower pan by the wall.
Hopefully yours is only the sink connection.
Eric F.
2015 Flagstaff Shamrock 233S
2012 Ford F250
Eric F. is offline   Reply With Quote
Old 04-10-2015, 08:21 AM   #20
fedrocker's Avatar
Small Leak
I'll take another look - don't think I have the same view behind the back panel as yours. The panel on the right is really fastened.
leak
