Originally Posted by carmine
I have a 2007 21ss Roo, I have some soft spots physically appearing on the floor, from the stove to the refer, NO water leaking going on. Anybody have any thoughts on this. and how long is the warranty on the flooring on this unit?
Well, you're probably out of your warranty & grace period.
I'm guessing (educated) that the soft spots are starting right where 2 pieces of underlayment are coming together. I've tried floor leveling compound to solve this, it doesn't work - no flexibility. Ended up replacing the floor. It might be a major repair, but try removing the linoleum, liquid nailing down some 1/4" underlayment, and installing new vinyl over the top. When you install the new subfloor, make sure you don't put the joints over the existing joints.
Scenario two: your lamination glue is letting go. It's going to get worse before it gets better. Your floor structure is gradually breaking down. The camper will last a very long time, you'll just have a bit of a squishy floor.
Scenario three: double check your frame cross members. Add more, if necessary.
