Old 09-28-2013, 06:28 PM   #1
Solar Panel
I have a 20w solar panel ...is it safe to connect..will it affect the trailers power inverter?
Marco is offline   Reply With Quote
Old 09-28-2013, 06:45 PM   #2
Ford Idaho's Avatar
How are you planning on connecting it?
Alligator clips, bolt on....
Old 09-28-2013, 08:07 PM   #3
I have a voltage limiter that is bolt on to battery terminals....panel plugs in to that..
Old 09-28-2013, 08:09 PM   #4
raspivey's Avatar
You can do it....no different than hooking up a battery charger to it, the charge controller you have will take care of regulating it. Whether or not you'll be happy with it all depends on what you want it to do. 20W isn't a lot of power if you want to extend battery life. Keeping them charged when not in use would work well.
Old 09-29-2013, 06:58 AM   #5
What amount would I need to give battery a full charge after a night of usage?
Old 09-29-2013, 07:06 AM   #6
Ford Idaho's Avatar
That depends on you and your trailer.
The more you have the less time it takes for a full charge.
http://www.google.com/url?sa=t&rct=j...Zk3x39X2UUZ04Q
Old 09-29-2013, 10:25 AM   #7
raspivey's Avatar
Look at your particular needs as well. I dry camp 2 - 3 times a year, generally in the fall, for 2 - 4 nights at a time. The rest of the time I'm plugged in. I figured that I burned about 20 - 30 Ah a day if I were running the furnace. It's really shady and mostly cloudy in my situation and I calculated 80W of panels would only replace about 50% - 100% of what I was using. It came down to cost....around $400 for solar or $70 for a second battery to accomplish the same thing. If I did it regularly, it would pay for itself in the long run, but not with the 2 - 3 times a year I need it.
Old 09-29-2013, 02:29 PM   #8
bikendan's Avatar
so not to confuse others, it's a power CONVERTER, not a power inverter.
your converter is what charges the battery when plugged into shore power or a generator.
all RV's have a converter, but only a few have an inverter from the factory, usually some motorhomes.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 09-29-2013, 02:43 PM   #9
Patches's Avatar
I have always kept enough panels that would equaled (+) my total the amp hours of my battery bank. I have a battery bank with 400 (500 gross) amp hours, and I run two, 250 watt solar panels when in use, while boondocking. Never had a problem with this set up. If it gets cloudy, I switch over to the wind generator.
"Full Timer" with "Boon Docking" in the desert southwest being my drug of choice. Well, that and really cold beer.
Patches is offline   Reply With Quote
Old 09-29-2013, 02:59 PM   #10
Ford Idaho's Avatar
I thought this was going to be a new RV park when I first saw it...
expandable, hybrid, shamrock, solar
