Old 07-23-2016, 07:11 PM   #1
Send a message via AIM to Chappie Send a message via MSN to Chappie
Solar Panel Help
I recently purchased a 2016 Rockwood Roo #183. On my first outing, which was 4 days dry camping, the CO alarm kept going off. I had the battery that came with the trailer tested and it was determined to be fine. The dealership suggested I add a second 12 V battery and bridge them together. I did just that and on my next 5 day dry camping trip, all went well. Now I plan to go dry camping for 10 days and feel the need to buy and hook up a Zamp solar panel to keep just the two batteries "topped up" during my trip. All our cooking is down outside on a stand alone gas grill or BBQ, the fridge runs on propane, I just need use the internal lights, and maybe the bathroom fan when I'm in the shower, and maybe the radio. Based on the Zamp Solar website, I am leaning towards the ZS-120-P unit. Any feedback would be greatly appreciated.
Thank you
Chappie is offline   Reply With Quote
Old 07-23-2016, 07:25 PM   #2
The fridge also uses 12VDC from the battery to run it's "brains."
2011 Traverse LT, 3.6L, FWD
Old 07-24-2016, 08:36 AM   #3
lablover's Avatar
We have been camping for over 2 months now and only had electric for 8 days. Mind you the truck charges the batteries each time we move. We use the Zamp 120 and it works perfectly. Our camping has been mostly in Utah, Arizona and Colorado so we have had plenty of sun. You should be fine.
2 Old Geezers
2 Labradorables
2015 Dodge Ram 1500-Rambo
2015 Roo 21BD-L'ABode
lablover is offline   Reply With Quote
Old 07-25-2016, 08:43 AM   #4
GracefulCamper
rocknroos's Avatar
I have a Roo 17. We have used it 5 times all of which has been dry camping. My goal is to be able to dry camp at least a week. I first started out with a 100 watt Renogy solar panel and their PWM charge controller. Towards the end of the week the battery was getting discharged and the CO/propane detector started to chirp. I then bought a second 100 watt Renogy panel and wired in parallel. They sell connectors to do this. I also bought a Blue Sky MPPT charge controller. on our next two dry camping trips we were able to go all week and the single 12v battery never got below 2/3 full all week, even with a couples of days of partly cloudy skys. I have about $500 in this system. I believe that a 120 watt Z-amp system would cost around $600 or so. The largest draw on the battery is going to be the water pump. I have attached some pictures and a word doc. listing the load demand from all the devices in my Roo 17
ID:	115226   Click image for larger version
ID:	115227   Click image for larger version
ID:	115228   Click image for larger version
2015 Roo 17
2010 Lincoln MKT
rocknroos is offline   Reply With Quote
Old 07-25-2016, 09:04 AM   #5
WolfWhistle's Avatar
x2 rocknroos
100 Watt 12 Volt Portable Solar Suitcase | Renogy Solar
Of course, there are many good manufacturers and products to fit any need. The key is to find the need and match it with a good system. They also has many other choices. I went with their 150w panels and a 30A trimetric charger/controller, but size matters in regard to what will fit properly on a roof. I have a lot of roof, so a suitcase was not considered.
WW
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
solar, solar panel
