Old 07-18-2013, 08:35 AM   #11
Grizzlygibbs's Avatar
Would a battery tender do the trick Triguy?
2008 Toyota Tundra Crewmax Limited w/tow mirrors, 5.7L, 4.30 gears, six speed tranny, towing package, Firestone Ride Rite airbags.
2014 Rockwood Roo 233s, PI HW30-C, Equalizer 10k 4 way hitch,
Grizzlygibbs is offline   Reply With Quote
Old 07-18-2013, 05:50 PM   #12
Good question. I have a battery tender too (the 12v one so I'd need to charge I series too). I know they sell a 6v version too.
I'm leaning toward the cosco batteries due to price and local availability.
2009 Roo 233
2005 Jeep Grand Cherokee 4.7L
Zoso is offline   Reply With Quote
Old 07-18-2013, 06:04 PM   #13
n1joh's Avatar
nice set up You going to the aug ralley? I have two panels on my coach I think they are 145 watts and the controller also I have 4 t-145 battires and connected to a 3000 watts inverter. I will be at the ralley in aug. I will be doing parking.
n1joh is offline   Reply With Quote
Old 07-18-2013, 11:32 PM   #14
Triguy's Avatar
Sorry to get back so late to your question Grizzlygibbs. We were travelling most of the day and then setting up the campsite. Now its miller time
The Trojan batteries need 14.8 volts in bulk mode, which is something the typical WFCO converter and some portable charger won't do. Because I haven't changed out my WFCO, yet, (for a Progressive Dynamics that can hit that mark), I use a portable Stanley BC4009 Automatic Battery Charger (40 Amp). This one can also recondition the batteries and is something Trojan recommends you do as needed to prevent sulfation. It think this feature is important to keeping your deep cycle batteries healthy and long-lived.
Sulfation occurs when a lead acid battery is deprived of a full charge, which will happen if the converter cannot charge to its recommended volts as explained above. Crystals form within the battery and eventually larger crystals reduce the batteries active capacity. See Sulfation and How to Prevent it.
As for the tender, I've got a battery tender on my AGM motorcycle battery. The battery tender helped that battery to last me 10 years but I don't believe my model is the best for deep cycle batteries (I'd have to check the specs but I don't believe it will provide the volts in bulk mode and it doesn't recondition).
If I were to leave it connected all the time in storage, then I would consider a Battery "Minder", which makes a number of really good charger/maintainer/desulfator units.
Hope this helps.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
