Old 05-29-2014, 09:41 PM   #1
Soon to be new Roo 19 Owner!
Pup is gone and deposit is in on a new Roo 19. Other than a sewer hose and no cranking the @!! $ roof up what do we need to know about the new rig?
Sent from my SCH-I545 using Forest River Forums mobile app
Buckeye X is offline   Reply With Quote
Old 05-29-2014, 10:01 PM   #2
mTn_biKer65's Avatar
There's at least one if not more good youtube vids on set-up for a hybrid. Worth a look for at least those tent ends procedures.
Chances are you'll be tearing down at some point during rain. Once the ends are closed wipe up what water you can and when you get home don't wait for good weather to dry them out. I'd set them up immediately rain or shine to get any water away from the wood on the deck and the hinge area.
Get familiar with the operations of your water heater. e.g. location of the electric switch and how to tell if it's full of water before you turn it on. Many stories here of burned out water heater elements because the water heater was empty especially on that first trip out.
Enjoy!!!
Nights camped
2007 Shamrock F19 hybrid - 2010 (22 nights), 2011 (24 nights), 2012 (11 nights)
2013 Surveyor Select 235RKS -
2012 (6 nights), 2013 (32 nights), 2014 (26 nights), 2015 (37 nights), 2016 (14 nights)
mTn_biKer65 is offline   Reply With Quote
Old 05-29-2014, 10:04 PM   #3
Went from a popup (20 yrs) to a Roo19. Mine is a 2012.
I have the old bunk latches, you'll have the new ones, which seem to be of dubious quality, per other posts on the forum.
My water heater inlet/outlet/bypass valves are junk. I have the metal ones, not plastic. Don't know what you'll have. The bypass valve failed to close first trip of 2nd season. Replaced it with similar POS.
You should get LED lights. I've got incandescents. You'll probably also get awning LED's - nice.
There's storage space across the front of the trailer, but it's tough to get to. One guy installed a door into it between the dinette and sofa so he can get to it from inside.
The triangle cabinet by the door needs a shelf. I haven't made one yet, but will this summer.
I installed a piece of clear plexiglass on the sink cabinet that faces the shower. Most Roo owners have done this. Caulk the edges. Keeps shower water from damaging the cabinet. Also installed a triangular shower shield - see pic.
There's a lot of wasted space at the outboard ends of the rear storage area, behind the tail lights. Haven't done anything with it yet, but the piece of paneling they put up will probably be coming out this year.
My furnace blows into the foot area of the dinette, which is exactly where it draws in it's cool air. Dumb design. Several folks have moved the air discharge to the side of the dinette bench so it blows into the walkway between the dinette and the stove. I've been led to believe FR fixed this on the newer ones, but don't know for sure.
Got a 2" memory foam topper for the mattress. Speaking of which - the heated mattresses are NOT like an electric blanket. They only put out about 150 watts (a good sized light bulb). You may not actually feel much heat when you put your hand under the covers, but when you crawl in and go to sleep, they work very well. Have done 40 deg F with the control set a mid-heat.
Turning on the exhaust fans (you've probably got 2, I've just got the one in the bathroom) when closing up, with the permanently fixed-to-bunks canvas is supposed to help you ensure the canvas gets in properly - sucks it in, so to speak. (I haven't tried this trick yet myself.)
I remove the mattress from the bunk before I close it up; others don't - they leave it snapped to the bunk. You'll have to decide what you want to do.
The dinette table legs are crap. Too heavy and too awkward to fold/unfold. Lots of complaints on the forum. Wish I had the simple X-style legs like on my popup, that just folded up against the bottom of the table independently. Easy and light.
We have had no leaks so far. (2 seasons, starting 3rd.)
You'll probably want to get a pair of BAL X-chocks for between the wheels. It will reduce rocking and rolling.
Many of us have done the vinyl fence post/rain gutter for holding the stinky slinky. See pics.
As a prior PUP owner, any similar issues/complaints you have you'll probably take in stride. So, please don't get the wrong idea - we're very happy with our Roo.
ID:	53783   Click image for larger version
Name:	Sewer Hose #1.JPG
ID:	53790   Click image for larger version
Name:	Sewer Hose #3.JPG
2011 Traverse LT, 3.6L, FWD
Old 05-29-2014, 10:37 PM   #4
Good info! The idea of only having to drop 2 bunks after a wet weekend is fanfriggintastic.
What about a breathable RV cover? Our Pup was a Coleman with the infamous ABS roof that self destructed in the sun so I am way over concerned about longevity.
Old 05-30-2014, 01:52 AM   #5
bikendan's Avatar
don't know if you had Popup Gizmos on your old pup, but you'll need them for your hybrid.
those and Reflectix in the tent windows will help with temp regulation and condensation.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 05-30-2014, 09:23 AM   #6
Why not keep the sewer pipe in the bumper? Rust?
Old 05-30-2014, 04:54 PM   #7
Yes, plus it doesn't fit very well (or not at all, depending on manufacturer).
My popup was a Coleman Sequoia with an aluminum roof, so no problems. These things have rubber/EDPM roofs. I have a cover I put on my over the winter, but not in the summer. We'll see how well it does over the long haul.
Old 06-16-2014, 09:05 PM   #8
We just went from a pup to a 2012 19 and love it!! Pretty much makes everything easier and more comfortable. Good luck with yours.
Sent from my Nexus 7 using Forest River Forums mobile app
jmcl528 is offline   Reply With Quote
Old 06-16-2014, 09:11 PM   #9
We've had one night of driveway camping!
Old 06-16-2014, 09:47 PM   #10
indybp57's Avatar
Did you fabricate that yourself or are they an aftermarket item?
Sent from my Kindle Fire using Tapatalk 2
2013 Roo 183
Miles Driven/Nights Camped:
2012:1042/13 2013:2772/27
2014:2259/30 2015:1644/20
2016:1278/23 2017:2183/22
indybp57 is offline   Reply With Quote
roo
