Old 05-19-2017, 08:38 AM   #21
Rooikss's Avatar
Excellent info here. Thank you so much. Heading out today for the long weekend. Hoping someone can help us out at the Park.
Rooikss is offline   Reply With Quote
Old 05-19-2017, 10:08 AM   #22
Be sure to travel with an operational battery. In the event that the trailer separates from the tow vehicle, the emergency breakaway brakes will only work with a charged battery.
Old- 2002 21 Roo
New- 2015 Shamrock 23 IKSS
TV- 2010 Nissan Titan CC
wharfrat48 is offline   Reply With Quote
Old 05-19-2017, 10:58 PM   #23
Rooikss's Avatar
Originally Posted by rockfordroo View Post
First thought: Is you battery disconnect switch turned on? On my Roo 19, it was inside, near the power center, down near the floor. It worked like an old car's headlight switch - pull out to turn on, push in to disconnect (off). If it's not inside, the newer models have it mounted to the A-frame in front of the battery under the propane tanks. Turns ON/OFF with a large red key.
But if you're initially getting a reading on the battery monitor inside, I would THINK it's already on. If that's so, I don't know why nothing works.
What exactly do you mean by "upon diagnostics the battery has a full charge"??
Thank you for all your help. I checked everything you advised and that I could think of and couldn't diagnose the problem. I hitched up anyway because I am booked for the long weekend at a park with full hook ups and proceeded on my 2 hr journey. Upon arriving and unhooking, obviously the 1st thing I did was attempt opening the slides on battery power and everything worked. I still believe there may be a loose connection somewhere. Mystery and stressful. Time to crack one open, kick up my feet and relax! Thanks again [emoji106]
battery, power
