Old 06-15-2013, 08:45 PM   #1
Speakers
We have a 2011 21ss roo with two indoor speakers and one outdoor speaker. Has anyone added a third indoor speaker? If so, what size and was it easy to splice into the original wiring?
Dvigna is offline   Reply With Quote
Old 06-16-2013, 09:22 PM   #2
redsuspenders's Avatar
Depends where you want to add the speaker.
Odd that you only have one outdoors. We have two on our 21ss.
If it is somewhere you can run the wires and access, then not a problem. If it is the ceiling, could be more difficult.
2011 Roo 21SS
2012 Ram quad cab
redsuspenders is offline   Reply With Quote
Old 06-17-2013, 05:38 PM   #3
My mistake, there are two outside. My thought was to add it at the top of the entertainment center.
Old 06-17-2013, 06:12 PM   #4
If you can get behind the radio, it shouldn't be too difficult to install, you would just splice into a or b, not c as that is outdoor speakers.
2011 Roo 21SS
2012 Ram quad cab
Old 06-17-2013, 11:24 PM   #5
cmcct's Avatar
There will be a set of "empty" wires coming out of the plug on the back of the unit.
Tow Vehicle: '92 F350, Crew Cab, 4X4, Cummins 5.9 24 Valve, 6spd.Driver:Clint, Navigator:Melanie, 1 dog (Great Pyrenees/Akbash cross) and now a cat too. Mission Statement: Just another adventure! Towed vehicle:2009 Roo 19 with lots of mods!
cmcct is offline   Reply With Quote
Old 06-18-2013, 09:48 PM   #6
urocav2001's Avatar
Does anyone have a picture if the back of the radio or how to remove it?
urocav2001 is offline   Reply With Quote
Old 06-18-2013, 09:56 PM   #7
TURBS's Avatar
What radio?
Model?
If its a concertone you need to carefully remove outer trim ring then remove 4 screws to remove radio.
You should always start a thread of your own instead of piggy backing on others as youse get better results.
Turbs
Old 06-24-2013, 01:44 PM   #8
grege's Avatar
I thought about doing the same thing aftrer camping in Florida for a week and watching DVD's. The sound plays over by the sink and the other bunk but we are usually in the bunk closest to the TV or on the sofa.
My plan is to make the indoor speakers a left and right on the A channel and then use the B channel for a speaker at the top of the entertainment center. Just need to figure out what speaker to use.
'12 Ford F150 Lariat Super Crew
'17 Grand Design Imagine 2800BH (Previous '13 Roo 21SS)
2016 Nights camped: 7
2015 Nights camped: 21
2014 Nights camped: 18
2013 Nights camped: 26
grege is offline   Reply With Quote
Old 06-25-2013, 04:03 PM   #9
Aqualight's Avatar
Adding speakers
I bought a pair of bookshelf speakers that include mounting brackets. I spliced into the speaker over the dining table (A), drilled a small hole through the cabinet wall and mounted the speaker under the storage shelf at the bunk end. Its tucked away in the corner and you cant see the wire or the small hole that the cable runs through. For the 2nd speaker, I spliced into the existing speaker wire over the stove, drilled a small hole inside the cabinet and ran the cable over to the other end behind the mircrowave. Drilled a small hole on in the cabinet end and mounted my speaker right in the corner. Can see any hole or cable and speaker reaches the other bunk since its right by the door. Very easy and the stereo has never overheated or shorted out.
As a wise man once said, "Wherever you go, there you are."
2018 Rockwood Roo 23IKSS
2010 Ford F-150 Super Crew Lariat
Previously owned a 2011 Rockwood Roo 19
Aqualight is offline   Reply With Quote
Old 07-02-2013, 12:25 AM   #10
jbdbsb
jbdbsb's Avatar
The factory stereo's are crap. I'm hoping to overhaul mine.
jbdbsb is offline   Reply With Quote
