Old 09-06-2015, 02:42 PM   #1
spline removal rockwood roo door
My grandson pushed a little too hard on the screen door of our Rockwod Roo 19 and now there is an opening on the screen. I can't figure out or see how to get the spline out to repair it. Any help?
dec1952 is offline   Reply With Quote
Old 09-06-2015, 02:53 PM   #2
Plain Old Member
Should be able to get it started with a tiny screw driver or something. Not sure if they make something specific for that or not. Easy to find spline installation stuff at the big box stores, but never seen a removal tool.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 09-11-2015, 02:03 PM   #3
Take The Road Less Travld
MuddauberE's Avatar
I had the same issue although mine was caused by my dog who was unfamiliar with what a screen door is . I did not have the right tool to remove the spline and there is a small corner nicked up a bit because of it. I was able to get it started out with a small nail and very small needle nose pliers, so if you have one of those pointy tools, that would work . The spline on mine was triangular? I reused it and the regular spline roller worked fine.
"Take The Road Less Traveled"
2013 Rockwood Roo 233s
2017 Ford F-150 EB
I've been an RVer since 2007, Lifetime Camper
Gotta love the Outdoors, Disconnect and Enjoy Nature!
MuddauberE is offline   Reply With Quote
door, rockwood, rockwood roo, roo
