Old 02-25-2014, 07:00 PM   #1
RoamingBadger's Avatar
Spray Paint?!?!?
So I had to take out 2013 21SS in because the paint underneath the slide out was peeling off. A good amount of it actually. Took it to my local camping world and they got on the horn with FR and went back and forth about it for weeks now. They made sure nothing was caught in the rollers or anything that would be causing it. Camping World is telling me that the reps at FR have received multiple complaints about the paint on the bottom. From what they said it was a bad batch of paint, and their solution? Spray Paint! They want Camping World to just get a can of black and go to town! Thankfully, the lady I have been working with said she will not do that since it provides no protection whatsoever.
My question is, has anyone else experienced this? What did you do?
2011 Ram 1500 w/ Timbren SES
2013 Roo 21SS
Blue Ox WDH
Nights camping 2013: 15
Nights camping 2014: 22
RoamingBadger is offline   Reply With Quote
Old 02-25-2014, 07:05 PM   #2
davel1971's Avatar
maybe spray undercoating or roll-on bed-liner kit would provide the results you are looking for
David & Lynn
Old 02-25-2014, 07:32 PM   #3
Perhaps it would, but a simple can of spray paint is the best Forest River can come up with as a warranty fix? Seems a bit ridiculous to me.
2013 Roo 21SS
Blue Ox WDH
Old 02-25-2014, 07:38 PM   #4
davel1971's Avatar
seems to be right inline with their build standards, unfortunately
David & Lynn
Old 02-26-2014, 08:36 AM   #5
KMP44's Avatar
I wouldn't be happy with this situation either, but I'm not sure there are many alternatives. You can't run the whole trailer down a powder coat line and replacing the slide could create more problems than it solves.
Don't let them just go nuts a $3 can of Krylon, but I would think if they properly remove the old paint, prep the surface, and use a good automotive paint in a spray booth you should get a quality finish that lasts for many years.
2017 F-250
2013 Rockwood Roo 23 IKSS
KMP44 is offline   Reply With Quote
Old 02-26-2014, 08:50 AM   #6
Ford Idaho's Avatar
Not sure why there is a problem with spray can paint because it can be automotive quality paint.
With proper prep work paint in a can should be just as tough and offer the same protection as any.
You do now that the body shops use a form of spray can.
Old 02-26-2014, 09:25 AM   #7
puff's Avatar
Getting paint to stick is all about prep work. What are you spraying...what kind of a surface..? Different surfaces require different prep work.
Glen & Robyn (A.K.A. Puff & Crickit) Full Timers..
2006 F350 6.0 with 3.73 gears, 4X4, Extra-Cab Long Box, Oil/Tranny/P.S. Coolers. Coolant filter. SCT Livewire.
2011 Cedar Creek 36RE, Auto levelers + too much to list..!
puff is offline   Reply With Quote
Old 02-26-2014, 07:45 PM   #8
phat phrog stunt crew
An automotive paint store will mix up a batch of primer and paint and ppput in an aerosol can. Surface prep is the key, clan clean clean. Buy a good quality paint altho some chassis black would probably be sufficient. I would prefer spray on to roll on.
Sent from ny nook using fairly accurate digits.
dwaynerz is offline   Reply With Quote
Old 02-26-2014, 08:28 PM   #9
Surveyor Mike's Avatar
From an auto painters point of view, I would be okay with a foam roller and two coats of quality paint. As stated clean the area well and SAND, so the paint has a "tooth" to grab on to with 320 grit or finer. Spraying causes overspray on all sorts of places you wont even notice till it's too late, especially spraying upside down. Not to mention the masking needed. Good luck in your decision.
2004 Surveyor 291 ultralite
2008 Ram 1500 quadcab Hemi
Surveyor Mike is offline   Reply With Quote
