Old 04-24-2012, 07:31 PM   #1
4kmprs's Avatar
sq foot limits
browsed through rockwood catalog and a lot of trailers were 9 ft plus tall and 8 ft wide, many tow vehicles have a 60 sq ft limit. is the basic calc. of height vs width appropriate or is a different calculation used? if basic, than an f150 technically is not supposed to pull any rockwood roo campers.
am i missing something?
Kevin, Meg and DDx2
2012 Rockwood Roo 233s
2004 F150 Super Crew 5.4L 3.73 4x4
Days Camped 2012 = 42
Days Camped 2013 = 9 planned before April 1st
Local Ohio CGs - Punderson SP and West Branch SP
4kmprs is offline   Reply With Quote
Old 04-24-2012, 07:42 PM   #2
Missing Link
cyclepuck's Avatar
I'm guessing your talking about the frontal area of a trailer. If so I never seen a sq foot rating on a tv.
2014 Puma 30-DBSS
2014 Ram 2500 Mega Cab 6.4L
cyclepuck is online now   Reply With Quote
Old 04-24-2012, 07:47 PM   #3
BOBFIDY's Avatar
Nor have I.....Maybe I"m missing something.
2011 FORD F350 CREW CAB DUALLY DIESEL 4x2
2010 Salem LA 292FKDS
One of the Original 14 F.R.O.G.s
1st, 2nd, and 3rd INTERNATIONAL F.R.O.G. RALLY Branson. MO.
1st, 2nd, and 4th INTERNATIONAL RALLY Goshen, IN.
BOBFIDY is offline   Reply With Quote
Old 04-24-2012, 07:50 PM   #4
4kmprs's Avatar
i havent seen sq ft numbers for tts eithe thats why i was calculating from the specs..
here's the brochure i was looking at
http://www.forestriverinc.com/nd/def...rec&choice=roo
here's where i saw ford 2004 frontal area considerations.
https://www.fleet.ford.com/showroom/...Equipments.pdf
Kevin, Meg and DDx2
Old 04-24-2012, 07:59 PM   #5
Missing Link
cyclepuck's Avatar
That is just stating to take frontal area into consideration when selecting a tv because of the extra resistance. Basically saying if you have a 500lb trailer with 96 sq ft of frontal area you might not want to pull it with a focus because of the lack of power. Plus your tv will be blocking a percentage of that area.
2014 Puma 30-DBSS
Old 04-24-2012, 08:05 PM   #6
The trailers are 9 foot plus tall, but you can't use that in your calculation. The 9 foot is from the ground, and the trailers don't drag the ground. You would need to know the height of the front wall, usually around 7.5 to maybe 8 feet. Some more, some less.
To be accurate, you need to know the height of the front wall, and the width, which is given. Also, the frontal area in tow vehicle ratings, is for a flat nose trailer, which I have, but not that many are. If you want to get in to slopes and curves, and "V" nose.... that would require a calculus class in night school.
Well, hope some of this helped. Just remember, height is from the ground, not true height of front wall.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 04-24-2012, 08:53 PM   #7
4kmprs's Avatar
ok google results
http://www.rv.net/forum/index.cfm/fu...d/24698487.cfm
this topic has been pursued before and appears to have no right/wrong answer.
oh well. i am enjoying the learning
Kevin, Meg and DDx2
Old 04-24-2012, 09:22 PM   #8
prof_fate's Avatar
Ford puts a SF rating in their manuals - and often other things. Tow ratings for YOUR SPECIFIC vehicle need to be figured out - you cannot go by the very general and optimistic figures you find online or in 'towing guides'. For example, according to my manual the 17" rim option reduces my GCWR by 500 lbs. You don't find that info online very easily, if at all. Tow ratings always assume a pretty stripped truck - so it weighs less so teh trailer can be heavier and still be under the GCWR. The 'books' say I can tow 8900 lbs when realistically 6000, perhaps 6500 is more like it, if i want to stay under the GCWR. That's a big difference.
One of the reasons I chose the trailer I did was because of it's very sloped front. My expy can pull it to 70mph no problem. I assume mileage drops as speed increases so I don't cruise at that speed, but it's nice to know I can if needed.
But the added drag taxes the drivetrain - as does GCWR of your loaded road ready rig. It can be handy to know what transmission you have - ford has made several over the years and in my case, I've got the 'big one' so I'm not too concerned about overtaxing it (as it's also used in F350s).
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
prof_fate is offline   Reply With Quote
