Old 03-27-2012, 07:34 PM   #31
cootr68's Avatar
Ya think I will buy a spare and rig it up.
1997 Sierra m-27fls tt
1999 Pontiac T/A
2006 flstn Deluxe
2004 Polaris 330 magnum
Bear the Labrador
cootr68 is offline   Reply With Quote
Old 03-28-2012, 05:25 PM   #32
Newbie
pg_rider's Avatar
You should be able to find these in several places for ~$6. I got mine at RVW when I was there. You can get it on Amazon for sure: http://www.amazon.com/Camco-57363-Leveling-Scissor-Socket/dp/B001V8U12M/ref=pd_sim_sg_1
2012 Rockwood 2306
2007 Honda Ridgeline tow vehicle with Equal-i-zer and Prodigy P2
pg_rider is offline   Reply With Quote
Old 03-28-2012, 06:39 PM   #33
B47
Originally Posted by Mark and Linda View Post
My attachment saves time for me. I keep my drill motor in the right front stowage area...start there and work around the stabilizers.
slightly off topic, but still pertaining to sockets - I was wondering what size socket I needed to remove the anode rod in our 29rk water heater when the times comes. After speaking to the dealer, I found it requires a 1 and 1/16" socket. I located one with a 1/2" drive at Sears - a little pricey (about $11) but I now have the right socket when I have to remove the anode rod.
Old 03-28-2012, 08:43 PM   #34
Mark and Linda's Avatar
I used a crescent wrench on mine because I didn't have a socket that big, even got my plumbing wrenches out. I put the crescent on it and then used a screw driver through the hole to turn it. Need to get a socket though...will look at Harbor Freight.
2009 Palomino Puma 25RS
2007 Chevrolet Silverado
Prodigy P2 Brake Controller
Mark and Linda is offline   Reply With Quote
Old 03-28-2012, 10:08 PM   #35
B47
M&L - you must have a different set up than I have (not surprising) as I don't have a hole that I need to stick a screwdriver though to turn the rod. It is a straight shot for me - but not having to use a crensent wrench and screwdriver is exactly why I spent the money for the socket.
