Old 03-26-2012, 04:17 PM   #1
Stabilizer Jacks
I knew I had another question :-)
SOmeone mentioned using a drill with an attachment on the end to raise and lower the manual stabilizer jacks on the ROO. I admit it is a bit of a pain to do it manually. Anyone done this? If so, what size is the attachment? DO you just keep a cordless drill in the camper?
Dtapp93101 is offline   Reply With Quote
Old 03-26-2012, 04:25 PM   #2
Rugged Brown's Avatar
I used this in the days of my manual cranked stabilizer. Worked like a charm. 3/4" socket with 1/2" adapter
ID:	11330   Click image for larger version
Terry/Bernadette
Lily the Yorkie
2019 Dodge Ram Sport 1500
2019 FR Vibe 28RL
Rugged Brown is offline   Reply With Quote
Old 03-26-2012, 04:43 PM   #3
buffalohunter's Avatar
Same here. Kept the drill and socket handy. Way faster and easier.
2012 Rockwood Windjammer 3008 W
2020 Tundra Dbl Cab 4X4 SR5
buffalohunter is offline   Reply With Quote
Old 03-26-2012, 05:24 PM   #4
Triguy's Avatar
3/4" socket. I just cut off the end of an old stabilizer jack. You could also use a six sided socket or buy a special one for $5 or $6 from your dealer. One of the biggest time savers there is. Very popular tool for anyone with manual stabs.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 03-26-2012, 05:29 PM   #5
Excellent, thank you!!!
Old 03-26-2012, 09:21 PM   #6
Mark and Linda's Avatar
I use a 3/8 in drive, 12 inch extension, that I cut the female end off, and a swivel, plus a socket on the end to raise and lower my stabilizers. You don't have to bend over that much when you use it. The extension fits into my Dewalt drill motor.
2009 Palomino Puma 25RS
2007 Chevrolet Silverado
Prodigy P2 Brake Controller
Mark and Linda is offline   Reply With Quote
Old 03-26-2012, 09:25 PM   #7
billy bob's Avatar
A cordless drill works great just be sure it has enough amps. I have used a Sears 19.2 cordless drill for years
billy bob is offline   Reply With Quote
Old 03-26-2012, 09:30 PM   #8
Photo of mine:
Name:	Adapter for Stabilizer Jacks.jpg
Old 03-26-2012, 09:43 PM   #9
fast murray's Avatar
Once you start doing this, you may get looks of amazement from fellow campers who haven't yet seen it.
2015 Sierra 357TRIP
2012 Ram 2500 CCSB 6.7CTD
fast murray is offline   Reply With Quote
Old 03-26-2012, 09:59 PM   #10
My attachment saves time for me. I keep my drill motor in the right front stowage area...start there and work around the stabilizers.
Old 03-26-2012, 10:19 PM   #11
cootr68's Avatar
I have the "old style"? Bal jacks that the end of the crank handle looks like a 3/8 male end. I haven't found any kind of drill adapter for them. Anyone know where I could find one? And there is about a 4 in. long tube it has to fit into
1997 Sierra m-27fls tt
1999 Pontiac T/A
2006 flstn Deluxe
2004 Polaris 330 magnum
Bear the Labrador
cootr68 is offline   Reply With Quote
Old 03-27-2012, 01:35 AM   #12
Drinkin beer on the beach
Rod Johnson's Avatar
What about one of those big Gator Grip sockets?
2014 Silverado 2500 6.6L TD and 4X4
2011 Carson Standard Duty Car Hauler
2012 Forest River Stealth SK2112
Rod Johnson is offline   Reply With Quote
Old 03-27-2012, 07:09 AM   #13
cootr68's Avatar
That mite work if I can get one that will fit in the tube. And find an drill extension long enough. Good idea thanks!!
1999 Pontiac T/A
2006 flstn Deluxe
Bear the Labrador
Old 03-27-2012, 07:16 AM   #14
PapaSmurf's Avatar
If you have the old style with the hole, instead of the hex nut end, I used a 1/4" Allen wrench in my drill to raise and lower them.
2011 Ram Truck 2500, Crew Cab, 6.7L CTD, 4X4, 3.73 Rear
PapaSmurf is offline   Reply With Quote
Old 03-27-2012, 07:47 AM   #15
cootr68's Avatar
I just went out and looked at it again. The gatorgrip won't work its female at the jack. The handle end is square like a ratchet extension.
1999 Pontiac T/A
2006 flstn Deluxe
Bear the Labrador
Old 03-27-2012, 07:49 AM   #16
A picture or pictures would sure help.
Old 03-27-2012, 07:56 AM   #17
cootr68's Avatar
1999 Pontiac T/A
2006 flstn Deluxe
Bear the Labrador
Old 03-27-2012, 08:01 AM   #18
Looks like you could buy an extension (3/8, 1/2 whatever) and cut the tail off, then chuck it into your drill. Would that not work?
Len & Cheri is offline   Reply With Quote
Old 03-27-2012, 08:09 AM   #19
cootr68's Avatar
Ya if it will fit in the chuck. Don't have drill and extension handy at the moment hopefully it will fit in the chuck and won't have to buy a bigger drill. Thanks.
1999 Pontiac T/A
2006 flstn Deluxe
Bear the Labrador
Old 03-27-2012, 08:11 AM   #20
mike54's Avatar
I started out using a 19.2v screw gun but the twisting hurt my wrists then I bought a 24v impact no more twisting work lot better than my screw gun
Mike & Marsha
2011 Signature Ultra Lite 8319SS
2005 Dodge Ram 3500 5.9 cummins diesel
https://www.facebook.com/WestAllisSunshiners
mike54 is offline   Reply With Quote
