Old 08-29-2016, 08:12 PM   #11
Originally Posted by jeff64 View Post
I've been using a 18v cordless drill. When the drill starts to slow down and twist in my hand, that's good enough for me
My drill has a torque setting (0 to 30). I don't know what the numbers actually mean in terms of ft-lbs or in-lbs, but I usually set it around 26 and crank them down until it torques out.
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 08-29-2016, 10:59 PM   #12
Usually Confused Member
emm-dee's Avatar
I do pretty much the same. Have a Makita cordless with six "torque" settings, with #six being full lock. I set it on five, run the scissor until torque release, and then give each jack 1.5 turns with the manual speed handle. That appears to put the same amount of pressure on each of the six jacks and no point on the frame is unbalanced.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
emm-dee is online now   Reply With Quote
power, stabilizers
