Old 08-18-2016, 09:25 PM   #1
Stabilizers and power jack
How much weight do you put on the stabilizers? I usually crank them a couple times after they touch the ground but then I noticed there is little or no weigh on the power jack. If I put more weight on the Jack then the stabilizers don't have enough pressure to work...any thoughts?
t0rnado is offline   Reply With Quote
Old 08-18-2016, 10:36 PM   #2
Robs1968's Avatar
I give my stabilizers on turn after they touch the jack pads.Seems to work well
Robs1968 is offline   Reply With Quote
Old 08-19-2016, 06:01 AM   #3
Sounds like you are putting way too much pressure on the stabilizers. The should not be used to level or elevate the camper, only to help eliminate rocking and sway. They work much better if you place several wood or plastic blocks under them rather thean extend them fully.
End result, the weight of the camper should rest on the tires and tongue jack, not the stabilizers.
Jim and Deb
Many times..asst grandkids
2015 Shamrock 23ikss
2013 Ram 1500
jking46 is offline   Reply With Quote
Old 08-19-2016, 07:03 AM   #4
Usually Confused Member
emm-dee's Avatar
What is your normal tongue weight? Mine is in the 1,200 pound range and I'm not strong enough to crank the scissor jacks enough to lift the tongue.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
emm-dee is online now   Reply With Quote
Old 08-19-2016, 07:15 AM   #5
SeaDog's Avatar
These are stabilizers and not jacks with that said what I do is get my rig level and then lower the stabilizers just until I see the trailer move up a little
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
AF&AM of Idaho
SeaDog is online now   Reply With Quote
Old 08-19-2016, 07:36 AM   #6
JustB_Rad's Avatar
I look at it this way....I always level the camper side to side first with a digi level on the floor inside the door. When I get the digi level within a 0.2 degree slope (less than 1/2") with my lego blocks, I stop. If I set my level up and I'm at 0.2 or less, I don't add any blocks. Then I level front to back and will put down my stabilizers. In most cases, I can make that 1/2" up with an extra turn or less on that side. Using this method, I've never seen the situation described above, and I'm always at a 0.0 in on direction and at worst a 0.1 in the other. I also added mid ship jacks which are my best indication of how far to put them down. After I put my corner jacks down, I move to the middle and put them down MAYBE a half turn after they hit the block.
2016 Grey Wolf 26DBH following a 2014 RAM 1500 Outdoorsman
Life is good...Live it!
(2014) Nights Camped - 16 in 6 trips (2015) Nights Camped - 20 in 6 trips
(2016) Nights Camped - 21 in 7 trips
(2017)16 Night Booked in 4 Trips - 6 in 2 more Trips Planned
JustB_Rad is offline   Reply With Quote
Old 08-19-2016, 12:31 PM   #7
Canadian Member
itat's Avatar
X2 They need to be snug, not lift the trailer.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 08-23-2016, 01:24 PM   #8
Boondocking Only
ddbck's Avatar
Just snug them up. I always re-snug after the 1st night due to settleg/shifting ext....
ddbck is online now   Reply With Quote
Old 08-29-2016, 07:12 AM   #9
Dave Lyon's Avatar
X2 !
After snugging up the stabilizers, I usually check them daily as they will work their way loose from the movement in the trailer.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
Old 08-29-2016, 07:17 AM   #10
jeff
jeff64's Avatar
I've been using a 18v cordless drill. When the drill starts to slow down and twist in my hand, that's good enough for me
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
power, stabilizers
