09-05-2018, 04:36 PM
Stabilizing Jacks-replacement
Hi all.....So, I was trying to be helpful on our last camping trip because my DH was injured. I was putting down the stabilizing jacks and I bent one!! Now I need to find a new scissor jack. A quick look on Camping World shows me there are several options....any opinions on brands? None are overly expensive, so cost doesnt really plan into this. I just dont want to buy junk! Oh, and Im not set on purchasing through Camping World. I just looked there 1st. TIA
09-05-2018, 05:22 PM
IMO, the brand isn't as important as the weight rating. I had to replace one on my unit so I bought a pair and replaced both fronts. The ones I got were rated at twice the weight of the stock ones. Much thicker steel.
Jim and Deb
Many times..asst grandkids
2015 Shamrock 23ikss
2013 Ram 1500
09-06-2018, 12:00 AM
look at etrailer dot com for replacement
2014 Shamrock 183
09-07-2018, 07:06 AM
Using a rattle gun?
I'm curious how one can bend a stabilizer (no stabilizing jacks on my Roo, just stabilizers). Procedure is to hand crank them down until they touch and then another half turn. There is some nice sprayable lithium grease that makes cranking them child's work,
-- Chuck
09-07-2018, 07:36 AM
I bent mine going up a steep hill to a site after dark. Replaced with ones from Harbor Freight. Cheap and easy. It was in my old trailer and they were great for the time I had it, at least.
Carmen and the pack
2015 Coachmen Clipper 17BH
2017 Dodge Durango Citadel 5.7 Hemi
09-19-2018, 03:19 PM
You can't much cheaper than the ones that come from the factory. I have swapped all of mine to BAL. Standard thickness for a jack is supposed to be over two inches, but mine from the factory were under two inches. I went to install the JT's Strong arm stabilizers right after purchasing the TT and discovered my factory jacks were garbage.
I love the JT's, and now each of the BAL jacks are rated at my gross weight. It's nice knowing I won't ruin these jacks with my impact wrench.
09-19-2018, 05:14 PM
I bent one of the rears in a dip heading out of a camp last year. Ended up replacing both rears with a pair from Harbor Freight. I keep putting off replacing the front ones. IMO, any brand you get will be better than the OEMs. They are just cheap.
2022 F250
2014 Rockwood Roo 233s
09-20-2018, 08:44 AM
If you're bending the stabilizers you're putting too much pressure on them. They're only there to stop some of the wiggle, not make the trailer as solid as your "double wide" on concrete blocks.
-- Chuck
09-20-2018, 08:54 AM
Professional Curmudgeon
I bent one of mine, too. Did some shopping at various dealerships and online. I believe the best deal available was on Amazon.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
They are rated at 5000 pounds each, and even though I only needed one, I figure it won't hurt to have a spare for the next time a cheap OEM jack gets bent. Plus, I got an extra cranks handle and a socket for my drill!
Good luck!
2022 Cougar Half Ton 24RDS fifth wheel
2014 Coachmen Catalina 253RKS (sold)
2017 F350 6.7L DRW CC LB 4x4 Lariat
09-21-2018, 07:09 AM
Light weight stabilizers (note how I avoid the term stabilizer jacks) are lightweight to protect the trailer frame from bending. I know lots of folks who will put a larger fuse if the proper one keeps blowing or substitute a steel rod for a shear pin on an outboard propeller. Sometime they get away with it. These are there to protect the system. The lightweight stabilizers are lightweight for the same reason. Hopefully they will fail before you cause permanent damage to the trailer frame.
I cringe when I see folks using rattle guns or drills to lower the stabilizers in lightweight framed trailers like the Roo hybrids and popups. The stabilizers are only meant to touch the ground. Breaking a stabilizer is the least of the damage you can cause the trailer when you bend the frame putting too much pressure on the stabilizers.
-- Chuck
09-21-2018, 07:18 AM
Kasual Kamper
Originally Posted by wrvond
Nope! Harbor Fright (pun intended) has them at $35 bucks each, also 5k rated.
https://www.harborfreight.com/2-1-2-...ack-96406.html
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
09-21-2018, 07:24 AM
Originally Posted by JayArras
Amazon link is two for $55 (or $27.50 each), HF is $35 each.
Current:
2019 Rockwood Roo 24ws
2016 Chevy Silverado Z71 4x4 DC
Past:
2001 Starcraft Spaceliner PU
1987 Starcraft Nova PU
