Old 04-03-2014, 10:06 PM   #1
duncmelsmom's Avatar
Sticker removal?
I'm cleaning up our Pop Up for Craigslist. We collected about 15 stickers from all over while traveling. I know the new owners won't want them, but I'm afraid that it's going to be quite an undertaking to remove each.
What should I use to remove them from metal? Goof off?
Or do you suggest that I just leave them alone?
I know it has to be all or nothing. I'm afraid if I get started, I'll make more of a mess than if I just left them on.
Thoughts?
Old - 2008 Niagara
New - 2015 23ikss
2007 Toyota Tundra Crewcab Limited
Family of 4: Hubby, me, 2 teenagers
1 Rat Terrier
duncmelsmom is offline   Reply With Quote
Old 04-03-2014, 10:14 PM   #2
GLCM Warrior
Lefty59's Avatar
Thoughts?
I'd try heating them with a hair dryer and see if they will loosen up enough to peel them off. If so, then I'd try using some Goo Gone or Bug & Tar remover to remove any residue. Worked well for us when removing those pesky car dealer ads from the new TV.
2014 Wildcat 312QBX
2014 Ford F350 SD 4X4 CC LB 6.7L PSD
Bob & Debbie, USAF Retired
Lefty59 is offline   Reply With Quote
Old 04-03-2014, 10:33 PM   #3
SKnight's Avatar
Yep, even if out in the sun use the hair dryer to warm the decals a bit more than the metal, they should peel off reasonably easy. Remove the residue as stated then use a good wax on the area to blend in where the decal sat.
Old 04-04-2014, 02:28 PM   #4
rburns4147's Avatar
Believe it or not but I have had good luck in removing sticker residue by using WD-40. Maybe I have been lucky, but it has not harmed any surface I have used it on.
Ron and Elizabeth
2014 Rockwood 8285-IKWS
2006 Ford F250 6.0 Diesel 4x4
rburns4147 is offline   Reply With Quote
Old 04-04-2014, 02:35 PM   #5
kerrlakelover's Avatar
WD-40...the wonder chemical. I swear by it and it's hundreds of uses. WD-40 Facts & Myths | WD-40 Ingredients
North Carolina born and bred
2010 Sandpiper 345RET
2011 2500 Duramax Silverado
2001 Centurion Elite Bowrider direct drive
"Old water skier"
Jesus Christ my Saviour
kerrlakelover is offline   Reply With Quote
Old 04-04-2014, 03:12 PM   #6
Ford Idaho's Avatar
I vote for the WD-40 as well.
Old 04-04-2014, 04:11 PM   #7
turnerpa's Avatar
I vote WD-40 all the way! I use it to clean sticker residue from everything! 2-stroke gas works as well and the oil in it protects the paint and clear coat from being "eaten" thru
turnerpa is offline   Reply With Quote
Old 04-04-2014, 04:34 PM   #8
Perfect! Thanks you guys!!
Old - 2008 Niagara
New - 2015 23ikss
1 Rat Terrier
Old 04-05-2014, 07:03 PM   #9
The hairdryer easily removed most of it. The WD-40 removed most of the rest. I have 1 sticker that left more residue after the "treatments". I'll try something else tomorrow.
Old - 2008 Niagara
New - 2015 23ikss
1 Rat Terrier
Old 04-05-2014, 07:15 PM   #10
Ford Idaho's Avatar
Denatured Alcohol or Nail polish remover.
