Old 11-16-2015, 07:44 AM   #1
wicked1's Avatar
Sticking Grey and Black Tank Release Handles
Anyone know how to free tank handles that have become hard to pull out? I can get them out but they are sticking pretty tight and I am afraid to break them, figure someone here might know a trick or two on a 23IKSS Roo
2014 F150 FX4 Crew 4X4 EB
2015 Roo 23IKSS
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
Old 11-16-2015, 09:10 AM   #2
rsscully's Avatar
I have used a little silicone spray on mine, you could probably use wd-40 also. Pull out as far as you can without forcing them and spray the metal stem. Work it back in and out applying the spray each time you gain a little more. Eventually they should loosen up enough where you can pull the whole way out and lube the entire stem.
rsscully is offline   Reply With Quote
Old 11-16-2015, 10:40 AM   #3
There is a small article on how to fix this problem in this month's Trailer Life magazine. Buy one and take a look.
Mikewcrook is offline   Reply With Quote
Old 11-16-2015, 11:47 AM   #4
I use WD40 once a season - very easy to do and works great.
...VTX Al
VTX Al is offline   Reply With Quote
Old 11-17-2015, 11:12 AM   #5
rsdata's Avatar
is it the slide handle or the part of the slide sides that are sticking? I would think that silicon spray would solve this.
magazine article
http://rvlife.com/techtipsavoiding-sticky-valves/
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
Old 11-17-2015, 11:20 AM   #6
Could be the valve itself or the cable. Try lubing the handle. If no help you may have to disassemble the valve
Harkerr is offline   Reply With Quote
Old 11-17-2015, 11:45 AM   #7
Thetford sells an additive for holding tanks just for the valve lubrication. See you RV parts store.
hillsdaletc is offline   Reply With Quote
Old 11-17-2015, 12:21 PM   #8
Lexi2007's Avatar
Mine did that one time. Then we had a poop jet.
Ken & Val [Lexi's mom] Moczygemba & Tori the dog
Adkins, TX
2017 Coachmen Concord 300 DS [Lexi III]
Lexi2007 is offline   Reply With Quote
Old 11-17-2015, 01:04 PM   #9
Tank levers
We had same problem. Still under warranty. Had to disassemble because it was the cables not the handles. The guys said it was very hard to replace because the whole belly in the basement had to be removed and the cable was in a tight area to reach. But it was covered and sent me the new cables to have replaced. Haven't had this problem since but it's only been a year since replaced.
alicemerrill is offline   Reply With Quote
Old 11-17-2015, 02:28 PM   #10
dicky1243's Avatar
I use the silicone on the shafts and i use the green tank cleaner it has a lube in it to help the valve too.
2006 Gmc
2016 Forestriver Sierra 376 BHOK
Full Timers
Dick,
dicky1243 is offline   Reply With Quote
black, black tank, tank
