Old 06-17-2015, 09:46 PM   #11
trbomax's Avatar
Ours rests in the driveway on stone, next to its personal dumpstation.
ID:	80322   Click image for larger version
trbomax is offline   Reply With Quote
Old 06-17-2015, 09:53 PM   #12
urocav2001's Avatar
Yes I would love to see the dimensions and clearance...
urocav2001 is offline   Reply With Quote
Old 06-18-2015, 12:21 AM   #13
Briorick's Avatar
Originally Posted by howie70 View Post
I had a smaller camper when I got the carport, but my 23LB fits with about 3-4" to spare above the AC (it also sits dead center). It takes it all up since the carport is only 21' and my camper is 23'8" from tongue tip to bumper. But, all of the body and roof is under cover.
As for recommendations, I measured the camper and talked to the salesman for the carports to get ideas. The sides obviosly are not as high as the center. I think mine is listed at 11' to the center (12' wide) however it has "crossbeams" for support that run across the center that are about 3' long so that takes away a few inches from the height. I could always remove them if needed. I put 4"x4" posts at the corners and bolted them to the metal legs to help with support.
I can snap a pic tomorrow if you would like to see the clearance.
Thanks Howie.....I would sure appreciate it if you could post a picture. Would give me a better visual of how your carport / HTT clearance looks as well. With my figuring, and with a 12' wide Carport, I am guessing I will only have a minimum of 24" on both sides of the camper if parked dead center under it. My HTT is approx. 7 1/2 ' wide.
I'm hoping the legs, which I know are 5' on center would be spaced enough to allow access into the HTT. I'm going to have to do some more marking and measuring on the pad to check my door clearance.
Thanks again, much appreciated!
Rick & Brian
1 Happy Camper Pup ( Mya )
2017 Salem Cruise Lite 232RBXL
2004 GMC Sierra 2500HD LT 4x4 6.0 / 4:10
The best plans can be of those that happen in the spur of the moment!
Briorick is offline   Reply With Quote
Old 06-18-2015, 05:01 AM   #14
camping baba's Avatar
We keep our 5r in a metal pipe framed garage with canvas roof and sides . It is on grass with good drainage .
camping baba is offline   Reply With Quote
Old 06-18-2015, 06:51 PM   #15
Here are a couple pic's. Mine has 9' legs. 11' to the bottom of the tin roof. I lose about 7" from the thickness of the metal framing and the cross member support. That could be removed though. So it is about 10'5" clearance.
ID:	80400   Click image for larger version
2016 Flagstaff 23LB
howie70 is offline   Reply With Quote
Old 06-18-2015, 07:46 PM   #16
Briorick's Avatar
Thank you. It is a PERFECT setup! The dimension of my HTT are pretty much identical to your TT ( I googled the stats ) so I can see it fitting nicely under the Carport. Our door is in the same position, so I got a visual of the clearance for the door as well.
BTW, I am loving your Micro Lite. This is one of the TT's we were originally looking at a couple years back. I love the layouts they have in them.
Hmmm , the good news is knowing I can utilize the same carport as yours for our current HTT..... the bad news is now "I know" I can later down the road use it "just in case" we decide to get a Micro Lite.
I would say that is a win-win!
Howie, Thanks again for the pics. They were a great help with my decision now.
Rick
Rick & Brian
Old 06-18-2015, 08:17 PM   #17
Glad I could help! We love the micro lite so far. This is camper #4 and hopefully the last one for quite a while!
I left the door open so you could see where it was in relation to the legs. I did put some pipe insulation on the leg just to be safe.
2016 Flagstaff 23LB
Old 06-19-2015, 07:24 AM   #18
urocav2001's Avatar
Did you make that yourself? Or buy it?
storage
