Old 08-27-2014, 08:22 PM   #11
CDNWhiskey's Avatar
Ok. Hmmm it's on the other side of the trailer from this end. Little more difficult to get into. I'll have to try later.
CDNWhiskey is offline   Reply With Quote
Old 08-28-2014, 08:48 AM   #12
KMP44's Avatar
Do you have a power awning? That would be where the 12V goes out to the awning motor.
2017 F-250
2013 Rockwood Roo 23 IKSS
KMP44 is offline   Reply With Quote
Old 08-28-2014, 09:47 AM   #13
My wire is spiced to a red and black wire that feeds through the outside wall right behind the awning support. I assume it goes to the motor but can't extend the awning right.
Delwood71 is offline   Reply With Quote
Old 08-28-2014, 10:24 AM   #14
Brother Les's Avatar
Originally Posted by CDNWhiskey View Post
Not near the fuses.
14 gauge. Marked "low voltage wire"
No power to it. I'm currently on shore power.
Just went to straight battery power. The wire is still not live.
So you did check it with a volt meter, 12v and 110? Are all of the 12 fuses 'in' the fuse box or is there any 'tabs' that do not have fuses in them?
Brother Les
Old 08-29-2014, 10:59 AM   #15
CDNWhiskey's Avatar
Checked with a meter. No power
Will check fuses later today.
Seems this might be for a power awning. I have a manual.
Now wondering if I can repurpose it and hook something up maybe a self installed accessory
Old 08-29-2014, 12:06 PM   #16
KMP44's Avatar
If it is a rough-in for the power awning option, the other end is probably at your switch panel. Might be able to connect to 12V behind there and use it for something (like LED awning lights).
2017 F-250
Old 08-29-2014, 12:29 PM   #17
CDNWhiskey's Avatar
Good suggestion!
