Old 08-14-2012, 09:24 PM   #1
studs in walls
Does anyone have or know how to get a picture or specs of were the studs are at in the wall of the slide out side of a 2008 roo 21ss. Above the slide does not seem to have any studs or any support on the bottom of the wall above the slide were the plastic white piece that the seal is attached to. Thanks is advance
l24x4 is offline   Reply With Quote
Old 08-14-2012, 10:07 PM   #2
Triguy's Avatar
Short of someone with the same '08 Roo, I would use my electronic stud finder.
What are you working on?
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 08-14-2012, 11:27 PM   #3
My wall above slide is rotted. in the middle the wall paper is REALLY soft and it don't seemed to be a piece of aluminum there at all. One on top of the wall but not on the bottom. Not sure what to do besides cry to sleep at night.
Old 08-15-2012, 04:08 AM   #4
great white's Avatar
Well, if you're handy its probably time to take the wall apart and replace the rotted parts.
If you're not handy I hope your wallet is heavy....
2011 Flagstaff Classic Superlight 831RLBSS "Atrium slide"
Husky Centerline Hitch
2016 Ford F-150 EcoBoost SuperCrew, Lariat Sport, Max Tow package
great white is offline   Reply With Quote
Old 08-15-2012, 05:54 AM   #5
The wall is a sandwitch type composed of a luan board, hard styrofoam and another luan all bonded together. The aluminum frame will be hard to find but if you use the proper picture hanger you should not have any problems to install the hook where you want. Most of the items are only screwed in the luan directly. When you insert the hook put a bit of crazy glue at the same time you insert the hook.
capucine is offline   Reply With Quote
Old 08-15-2012, 06:12 AM   #6
Picture hanger?
Did I miss something?
I thought he was talking about fixing a rotted wall......
Old 08-15-2012, 06:42 AM   #7
TURBS's Avatar
Originally Posted by great white
Picture hanger?
He was talking about fixing walls.
Picture hanger aka stud finder !
Old 08-15-2012, 06:45 AM   #8
Ah, I see where I mixed it up.....
Old 08-15-2012, 07:03 AM   #9
But what's this about a hook?
Len & Cheri is offline   Reply With Quote
Old 08-15-2012, 10:30 AM   #10
great.
Now I'm mixed up again.......
Old 08-15-2012, 10:38 AM   #11
Triguy's Avatar
I am sorry to hear this. You may have already done it, but have you identified the cause of the water damage? Was it the roof, seals, window? You get the point. Replacing the effected areas will be necessary, of course, but the cause needs to be addressed as well.
Good point. Just curious l24x4, do you intend to do this work yourself or have a dealer or experienced friend do this?
Scott
2012 Shamrock 233S
Old 08-15-2012, 07:00 PM   #12
Well I tore into it alittle today. No form board one stud running along to top of the ceiling. Looks like a rim board glued to the stud and laminate on both sides of it. No stud on bottom. The roof and all seams have Rv tape and the seal above the slide has tape too. Thinking the water is somehow getting pass the slide seal and the plastic cup on the bottom off the wall above the slide is trapping it and all is getting sucked up into the wood. Just don't know how to get rotten wood out without braking the fiberglass on the outside. And don't know really how the water is getting in. But the only spots that are affected are right above the slide. Here's a thought. If there is no stud on the bottom and no studs running up and down because what will they attach to. And every time the slide is ran out. You would think it would pull the wall on top out just a little and over time the screws on the outside that holds the roof down where the fiberglass meets would start to loosen maybe. Hell I don't know. But your right if I cant find where the leak is fixing it would be a waste of time. But for now just getting the rotten wood out would be a start. Any suggestion would be a big help. Sorry for the book.
Old 08-15-2012, 07:38 PM   #13
Unfortunately, to do a proper fix on the wall above the slide opening would require the removal of the slide, and that is not a small job. Sorry.
bakken is offline   Reply With Quote
