Old 01-20-2016, 04:56 PM   #11
Left Coast
Mine is behind
Old 01-20-2016, 09:48 PM   #12
Originally Posted by TURBS View Post
Look inside the cabinets on either side of furnace for a grill or lack there of.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
The wood cabinet panel that is directly behind the furnace is the grate or air vent. There is no other vent inside the cabinet. I confirmed this with Forest River. They were not very much help with my situation. They of course told me to contact Suburban, which I wasn't successful in doing.
JDZO6C5 is offline   Reply With Quote
Old 01-20-2016, 09:58 PM   #13
Im going to check the intake and exhaust ports on the outside to see if there is any obstruction of air flow, but I am just contemplating the thought of just replacing the sail switch to see if that does anything. I don't really want to, since that requires pulling the entire furnace out, but obviously that may have to be my next step anyway if the intake and exhaust ports are not obstructed.
Old 01-21-2016, 07:00 AM   #14
TURBS's Avatar
So the intake is inside a cabinet? Is there another intake from the cabinet to to camper?
Or is it just trying to suck air from the cabinet?
2015 Columbus 320RS
2008 2500HD Duramax
Old 01-21-2016, 07:43 AM   #15
Originally Posted by rbq View Post
The exhaust vent for this furnace should have 2 parts. One part to exhaust & the other part to draw in outside air for combustion. Are they both clean? Another thought is that when I had my PUP I used to have the same problem of the furnace not igniting properly. My brother opened up the case & put a stiff piece of electrical tape on the sail switch to make it bigger. It worked fine after that. Might want to see about increasing size of sail switch with some tape.
Not trying to hijack this thread, but, if you had to add to the sail switch to make this furnace work, you are not flowing enough air either. This would increase the exhaust temps and possibly overheating of the unit.
Filthy Beast is offline   Reply With Quote
Old 01-21-2016, 08:28 AM   #16
TURBS's Avatar
Agreed!
Could be a restriction on the heated air side to the registers.
2015 Columbus 320RS
2008 2500HD Duramax
Old 01-21-2016, 08:51 AM   #17
Head Rambler
Originally Posted by JDZO6C5 View Post
I agree with you. The problem is my battery at 100% charge only reads 13.4 volts on the meter. Any where from 12.6 and up is considered full charged. The sail switch should close with the blower even if the battery is not 100% charged...
I 100% agree. My point was to indicate that there is a problem with the furnace that needs to be rectified. Sorry I wasn't very clear about that.
...My point is my battery will never be at 13.8 and it shouldn't have to be either in order for that blower to close the sail switch.
We agree on this. There's definitely something wrong. My guess is an obstruction, but it could be something else.
Gotta go campin!
Old 01-22-2016, 11:59 AM   #18
pkenley's Avatar
JDZO6C5 After spending one fall in Silverton Co without furnace working, This last fall I was thinking it was an altitude issue as well.(worked in Dorango on shore power), . so I too pull the cover off as you did and it worked fine. Spent 4 weeks in comfort. Today, back home, I put the cover on and it works but I;m on shore power now so I might go back out and pull the plug and see if it works.
Phil & Carla Kenley
2014 Rockwood ROO 21ss
2013 Ford 150 Platinum Crew Cab
(Looking at the Georgetown 329DS)
Nights camped in 2011/16; 2012/15; 2013/48;
2014/10; 2015/101 2016/55 yr to date
pkenley is offline   Reply With Quote
Old 01-22-2016, 06:27 PM   #19
Have seen a few of these. You need to install one more duct. Your furnace is pushing more air flow than your duct work can handle. This loads the blower motor and causes it to draw more ampherage. As mentioned earlier the converter puts out a strong supply of amps to fully power the double blower wheels.
Too little air flow will also cause the temp. Limit switch on the furnace to kick out and shut down the furnace.
You need another duct.
hillsdaletc is offline   Reply With Quote
Old 01-22-2016, 07:38 PM   #20
pkenley's Avatar
and this will solve the issue when it's only a problem at high altitude??
Phil & Carla Kenley
furnace, suburban
