Old 03-15-2016, 12:02 PM   #1
Surge protector need???
I was unaware of the need for a surge protector until today. We are brand new to owning a trailer and we are going camping tomorrow for three days. I can't get a surge protector today and need to order online. Would you risk it and still go camping and just hope everything is OK or would you cancel your long awaited camping trip with the kids? Any temporary ways to fix this til we get our surge protector?
Kaboingy is offline   Reply With Quote
Old 03-15-2016, 12:17 PM   #2
Camped for over 40 years and never had a surge protector, Never had any problems
with out one, I bought a New class C and it had one installed, If it did not i would still be hooking up without one.
Have a great trip.
Kevin & Judy is offline   Reply With Quote
Old 03-15-2016, 12:24 PM   #3
BamaBob's Avatar
Kevin has famous last words Kaboingy.
It depends. WHERE are you going camping? If it is a "Spring Break Resort" you are likely to be OK (more so than a rustic campground with questionable power.)
By chance are you a Amazon Prime member? If not you CAN get a temporary membership and cancel later if you wish. You can order a EMS today and it should be waiting for you at the Campground when you arrive tomorrow.
Not knowing what sort of camper you have, here is a link to the progressive EMS page on Amazon:
Robot Check
FWIW, we have camped for 25+ years and now that I know what I know, I would never hook up my expensive RV without a EMS -- just too many high strung electronics on modern RVs (versus what they were like even 10 years ago)
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 03-15-2016, 12:30 PM   #4
TURBS's Avatar
Only takes one hit to take out $4000.00 worth of electronics.
Progressive industries hardwired is the only one I'd recommend .
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 03-15-2016, 12:30 PM   #5
Witch Doctor's Avatar
If the weather is good just go for it until you can figure out what you need. You can go to ACE and by a cheap plug in meter that will tell you if your pedestal is wired correctly. Don't let it stop you.....
Coachmen M/H
Concord
2018 / 300 DSC
Old 03-15-2016, 12:48 PM   #6
grumpy0374's Avatar
2015 Columbus 320RS
2008 2500HD Duramax
X2. Cheap insurance. Just a circuit board for the fridge, ac unit, or even a tv set runs twice what a PI hardwired EMS runs. One bad surge without one will cost you big bucks.
Grumpy
grumpy0374 is offline   Reply With Quote
Old 03-15-2016, 12:57 PM   #7
In my opinion, the more important protection is from improperly wired outlets and low/high voltage conditions. A simple tester from the hardware store and a pocket DVOM can tell you when you hook up if things are ok, at least at that point in time. As far as I have heard, the greatest cause of the voltage fluctuations in the campgrounds are when everyone is using their A/C units and they are all cycled on almost constantly. That is not so likely this time of year.
I have the same mindset as TURBS... My wife was not interested in learing what to check before plugging in and didn't want the hassle if she went somewhere on her own, so a Progressive Industries hardwired unit was worth every penny to me. The popup only had a control board on the furnace so there wasn't much to fry in it so I never bothered.
I would not cancel your trip. Just do like I used to with the popup. Pick up a circuit tester like one of these...
http://www.menards.com/main/electric...00782625430300
And you should have a cheap DVOM to keep in the camper anyway. You can get both for less than $20.
  1. Plug circuit tester into outlet using a 30A adapter (i.e. test the 30A outlet not the 15A as I have seen one wired correct and the other backwards)
  2. Read the lights and if it indicates good, test the voltage...
  3. Put the DVOM on AC volts and you should have 105-128 volts.
I personally don't like to see as low as 105 but if you aren't running the A/C it would be fine. This is what I did for our first couple of trips before I could get our EMS installed.
dragon-roo is offline   Reply With Quote
Old 03-15-2016, 01:08 PM   #8
P.S. Like one of the others said... think of an EMS unit as an insurance policy that you pay for once and get to have it for the life of the trailer and can even take it to the next. If you think about how many days you will enjoy your camper over the next 10 years. The cost per day is tiny.
Even with the EMS I still use the circuit tester everytime before I plug in... I know the wife won't though.
The bank owns a good portion of our Roo at this point so I feel it is my responsibility to protect it for them (and maybe improve it a bit too)
Old 03-15-2016, 01:37 PM   #9
TURBS's Avatar
Have a great trip.
I've lived for 20 years before I met the president of the United States to.
You only get one chance!✌️
2015 Columbus 320RS
2008 2500HD Duramax
Old 03-15-2016, 01:39 PM   #10
Just saying !!!!
And yes we do check the plugs at the campground.
Nuff said .
