Old 09-09-2014, 07:37 PM   #41
deartruc's Avatar
excellent. The circuit breaker is one of my winterizing steps. Switch the breaker off (though with the electric element switch in the tank access panel) you are less likely to switch it on when there is no water in the tank.
2017 GMC Yukon
2018 Roo 23 ikss
deartruc is offline   Reply With Quote
Old 09-09-2014, 09:04 PM   #42
If drainage is good what does soapy water on the ground hurt. Of course if there were five a day I get it. No food in it. Tent Campers wash dishes outside and dump the water
Trayscott is offline   Reply With Quote
Old 09-10-2014, 05:10 PM   #43
Because people do it doesn't mean it's legal. If it's not black water, it's usually considered grey water and isn't to be dumped on the ground.
2011 Traverse LT, 3.6L, FWD
Old 09-10-2014, 09:39 PM   #44
n4uaj's Avatar
When we had our popup we usually stayed beside the inlaws with full hookup so we would just take our dishwater and dump it down the sewer hole on our site. I'm pretty sure every CG I've ever stayed in forbade you to throw out grey water on the ground.
Bill
2014 Shamrock 183
1995 Chevy Silverado
n4uaj is offline   Reply With Quote
Old 09-15-2014, 10:07 AM   #45
n4uaj's Avatar
Taking showers in the Roo
Sure would be nice if that stopper came all the way out. I think I stepped on it and shut it the other night and had a slight overflow:-)
Update: My Bad. DW took it out all should be well next time:-D
Bill
2014 Shamrock 183
Old 09-20-2014, 12:27 PM   #46
Shower Curtain
You don't have to deal with the shower curtain against your body while showering. An aftermarket fold-out shower curtain rod for RVs works great. It provides about 6 inches or so of separation in the shoulder area where you need it most. When you're done showering it folds back into the shower stall to drain and it provides more freedom of movement in the bathroom. I've been using one for a couple of years now. I can attest to its benefits. Unfortunately however, I couldn't find one short enough to fit my Roo's shower, so I had to shorten the one I bought. It's not difficult, but it takes an hour or two to do it right. If it's too long you can't fold it in or out.
part-timer is offline   Reply With Quote
Old 09-20-2014, 02:41 PM   #47
Not so hot for corner showers.
Old 09-20-2014, 06:46 PM   #48
I agree. After my DW bought one, I had to prove why it did't work.
Nccamper is offline   Reply With Quote
roo, show, shower
