Old 08-31-2012, 10:20 AM   #11
TURBS's Avatar
Originally Posted by Road-King
"You are correct Sir." (Phil Hartman)
Now some may saaaaaay that well they could push the electric button that opens gate valve .......... I say oh contraire monfraire weeeeeeeell how about installing the remote awning module on the gate valve !!!!!!!
Lol I kill myself sometimes !
And sometimes I need whatever it is that "youroo" takes every morning !
Old 08-31-2012, 10:50 AM   #12
Road-King's Avatar
If you don't want to go with turbo's electric shock treatment or the remote control.
I would think you could drill a hole in the handle, get some small gage cable, run it through the handle hole then around the drain pipe, crimp a loop to each end, leaving just enough cable so the handle can not be pulled and put any old pad lock through the two loops...
Russ & Kim
2014 Alpine 3600RS
2007 Dodge Ram 3500 5.9 4X4
2008 Harley Davidson Road King 105th Anniversary
(2011-5 bad year)(2012-40)(2013-45)(2014-23)
Road-King is offline   Reply With Quote
Old 08-31-2012, 10:56 AM   #13
TURBS's Avatar
You made me laugh lol shock therapy !
Yes that's a cheaper alternative .
Old 08-31-2012, 10:59 AM   #14
punkaccountant's Avatar
Here was my solution to that problem Twist-on Valve - Valterra T58 - Sewer Fittings & Adapters - Camping World
It's basically a 3rd valve that twists where the sewer hose is connected. As long as this valve is closed then you really limit any unforeseen spillage when you go to connect your sewer hose. Works like a charm.
http://www.forestriverforums.com/attachments/signaturepics/sigpic20864_3.gif
2013 Rockwood Mini-Lite 2306
2011 Ram 2500HD Hemi
punkaccountant is offline   Reply With Quote
Old 08-31-2012, 11:22 AM   #15
Herk7769's Avatar
Oh yea! That is my solution.
Other advantages include being able to transfer gray water to the black tank in an emergency.
HAM CALLSIGN - KC3FFW
Old 08-31-2012, 11:43 AM   #16
Rugged Brown's Avatar
How is that achieved? I'm assuming by openeing both grey and black gates, the fluids will equalize in the tanks?
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 08-31-2012, 11:47 AM   #17
Road-King's Avatar
The more I thought about it, I don't think you would even need to drill the hole in the handle. Just place the two loops on the ends of the cable over each side the T handle. Then lock the two loops together. The important thing is slack, not too much in the loops, between the loops or to big loop in the pad lock.
Russ & Kim
2014 Alpine 3600RS
Old 08-31-2012, 12:39 PM   #18
Herk7769's Avatar
Yes.
As long as the gray tank is full and the black tank is less than half it will work.
Basically, you make sure the end of dump mast valve is closed and open the gray water valve. This fills the dump mast with gray water. Then you open the black water valve for just a few minutes and the flow will be from the mast to the black tank. Close the black tank valve and then the gray valve.
This should transfer 5 or 6 gallons from the gray tank to the black and should extend the time till you have to dump a bit. It will also make sure your black tank is full when you do dump it.
I said this was an emergency procedure since there is always the possibility that solids from the black tank "could" migrate over to your gray tank if not done correctly or you let so much water transfer that there is a back flush into the mast before you can close the gray valve.
