Old 08-31-2012, 09:08 AM   #1
Namthor's Avatar
Tank Locks
I have had 2 incidents with jokster's pulling the black tank valve while in a rest stop and at a campground resulting in a nice mess when hooking up the sewer line. Anyone know of a locking system for for the valves?
Namthor is offline   Reply With Quote
Old 08-31-2012, 09:12 AM   #2
Keep the tanks empty while towing and the sewer hose connected when in a campground. Also, installing a clear elbow and leaving it on with a cap will alert you to what's waiting for you.
Old 08-31-2012, 09:21 AM   #3
TURBS's Avatar
Hook the valve handles to 110 v !
Buy an electric dump valve vs a manual handle ?
Old 08-31-2012, 09:23 AM   #4
Spend a lot of bucks when keeping them empty or hooked up is free? Surely you jest!
Old 08-31-2012, 09:40 AM   #5
TURBS's Avatar
He's saying that they pull the handle when it's empty then when hes camping the tank fills and he hadn't realized it was open the whole time .
Soooooooooo when he pulls off the cap ............ well you get the point.
U need to up your prescription level on those ole tri focals ? Lol !
Old 08-31-2012, 09:47 AM   #6
... U need to up your prescription level on those ole tri focals ? Lol !
"jokster's pulling the black tank valve while in a rest stop and at a campground resulting in a nice mess when hooking up the sewer line.
Ya'll need your's checked.
The clear 'capped' elbow solves both situations. But hooking the slinky up as soon as you get to the campground solves the other.
Old 08-31-2012, 10:01 AM   #7
TURBS's Avatar
Lol so if the clear cap is full he's still got the same issue ! only now he can see it's there .
Clear elbow won't help the trickster not pull his handle.
Old 08-31-2012, 10:08 AM   #8
Road-King's Avatar
Not to but in, but I will anyways.
With the clear end attached he would know somethings wrong if there is stuff in there. So he would check the tank valve and close it. Less "O'h Sh!$'s" and less mess to clean up...
Russ & Kim
2014 Alpine 3600RS
2007 Dodge Ram 3500 5.9 4X4
2008 Harley Davidson Road King 105th Anniversary
(2011-5 bad year)(2012-40)(2013-45)(2014-23)
Road-King is offline   Reply With Quote
Old 08-31-2012, 10:12 AM   #9
TURBS's Avatar
True.
Again doesn't solve the issue at hand.
Op wants to lock or disable tank valve whilst traveling to and from.
Wouldn't an electric valve gate solve is issue ?
Old 08-31-2012, 10:16 AM   #10
Road-King's Avatar
True.
"You are correct Sir." (Phil Hartman)
Russ & Kim
2014 Alpine 3600RS
