Old 06-20-2014, 05:15 PM   #1
coryhynes's Avatar
Tank sensor monitor
Hi. I am having an issue with my monitor panel. It seems that when my travel trailer was manufactured the grey and black tank wires were switched. Does any one have the same panel and know the proper wiring? See pictures showing how it is right now. I thought it would be as easy as switching the red and white wires but now nothing works.
Haha. Need help.
Sent from my Nexus 4 using Forest River Forums mobile app
ID:	55865   Click image for larger version
coryhynes is offline   Reply With Quote
Old 06-20-2014, 05:54 PM   #2
Herk7769's Avatar
Sorry to say you switched the 12 volt DC positive and negative.
MIGHT be time to buy a new wall monitor.
The gray and the brown should have been switched (provided they were not correct initially). Yours look correct as pictured.
Looks like (top to bottom)
Red
White
Gray
Brown
Blue
Good news - only 20 bucks...
http://www.ebay.com/itm/Fresh-Waste-...8ff2c0&vxp=mtr
File Type: pdf KIB Monitor Panel M21 Wireing Diagram.pdf (51.2 KB, 21 views)
HAM CALLSIGN - KC3FFW
Old 06-20-2014, 06:33 PM   #3
Evereddie's Avatar
You should not have switched the wires. Just switch the labels. Da Dahhhh
Evereddie is offline   Reply With Quote
Old 06-20-2014, 07:02 PM   #4
You could have switched the wires at the tanks.
2011 Traverse LT, 3.6L, FWD
tank
