Old 07-15-2014, 09:49 AM   #1
Tent end damage
So my tent end was replace late last summer under warranty as it had gone soft. Noted that it was still leaking. Dealer installed some metal squares around door hinge to put more pressure on door. Still leaked. Noticed that gasket wasn't high enough so they moved gasket. Just took trailer out of storage last week and did our first weekend of camping and noticed cracking. What are peoples thoughts on this. Cracks run lengthwise and it seems the metal is bent.
ID:	58226   Click image for larger version
ID:	58227   Click image for larger version
mvaughan is offline   Reply With Quote
Old 07-15-2014, 09:05 PM   #2
CDNWhiskey's Avatar
Tent end damage
Stress cracks. The extra pressure was too much buckled the metal. Silly fix in my opinion. That wasn't the problem.
Curious - do you still have a leak?
CDNWhiskey is offline   Reply With Quote
Old 07-16-2014, 06:18 AM   #3
Could be that water got into the seal and expanded when frozen and cracked it also.
2008 F150 v8 5.4
2015Rockwood Roo 23SS
2015 Nights Camping: 39
2016 Reserved: 23
Davylee is offline   Reply With Quote
Old 07-16-2014, 06:57 AM   #4
No, no leaks after they moved the rubber gasket on the inside of the trailer back to where it was supposed to be. Still had leaks after square washer was installed. No water damage on that area. No where for water to get into caulking is all good.
Old 07-16-2014, 08:24 AM   #5
CDNWhiskey's Avatar
I suspect the issue was always your rubber seal then and not the pressure of your door pinching closed.
With your cracking being identical on both sides safe bet it's the added metal squares causing stress to the metal edging. If you close the end can you or someone watch to see if that metal edge flexes or bends when it pinches closed?
