Old 06-01-2014, 12:47 AM   #1
PineForestCamper's Avatar
Thermostat Modification...Will This Work?
I am preparing to change out the thermostat that came with my Roo 233s and want to go digital. I was ready to go the typical route and install a Honeywell home model that runs on batteries until I stumbled on this which would leave me with the option of running the fan on high and low. When you install the Honeywell you only have the option of running on high. I hesitate because of my concerns it might not be compatible. Has anyone installed this? Thanks for the input.
Black Digital Thermostat Model AR7853 RV Comfort 8330 386 Coleman Mach | eBay
2009 Chevy Silverado/2500/6.0/3.73/CC
2016 Keystone Outback 250URS
2013 Rockwood Roo 233s (SOLD)
http://instagram.com/pineforestcamper#
PineForestCamper is offline   Reply With Quote
Old 06-01-2014, 06:27 AM   #2
Just put the 8330-3862 in my 23IKSS and it is AWSOME!! Very accurate. You will love it. GREAT price too.
Les & Heidi Kramer
2010 GMC Sierra SLE & 2014 Shamrock 23IKSS
Cleveland, OH
cpd1343 is offline   Reply With Quote
Old 06-01-2014, 10:06 AM   #3
Good feedback. Can you answer these questions...
1. Does it run on batteries or only 12v
2. Match up wire for wire when connecting
3. How do the wires connect with the wires in the camper..require any cutting of wires etc.
Thanks for the positive feedback.
Old 06-01-2014, 05:45 PM   #4
1. 12 volt only, has no batteries
2. Matches wire for wire
3. The original installation used wire nuts. I used crimp connectors.
4. Uses same screw holes to mount to wall.
Les.
Les & Heidi Kramer
Cleveland, OH
Old 06-01-2014, 09:30 PM   #5
Great information again. I am looking forward to keeping full functionality with this. Its a bit more expensive but not excessive and I dont have to change any batteries! I have made the purchase. Thanks Les.
Brad
Old 06-02-2014, 07:46 AM   #6
So it runs off 12v only. So im guessing that if im boon docking and on house battery i could not run my heater. Im looking to make the swap myself. The thermo thats in my tt is not very accurate. I turn it down to 65 and the temp is around 78 running the ac. and this can be on a 80 degree day outside. same goes for heat.
2013 Ram 1500 (5.7)
2014 Rockwood Mini Lite 2104s
http://i307.photobucket.com/albums/n...ps412bc14c.jpg
Prothos is offline   Reply With Quote
Old 06-02-2014, 08:32 AM   #7
Yes, it has a slide switch with off in the middle and a/c to one side and heat to the other.
Les & Heidi Kramer
Cleveland, OH
Old 06-02-2014, 09:02 AM   #8
Grizzlygibbs's Avatar
Your heater runs on 12v, ie your battery and does not require 120v. However it can drain your battery quick. Also might be worthy to note that by adding this modification, it is just another object that steals battery power, not sure how much but just be prepared.
2008 Toyota Tundra Crewmax Limited w/tow mirrors, 5.7L, 4.30 gears, six speed tranny, towing package, Firestone Ride Rite airbags.
2014 Rockwood Roo 233s, PI HW30-C, Equalizer 10k 4 way hitch,
Grizzlygibbs is offline   Reply With Quote
cat, thermostat, modifications
