Old 06-14-2014, 12:13 PM   #1
thestrangebrew's Avatar
thermostat replacement question
Getting ready to replace oem thermostat with a Coleman mach digital unit and had a quick question about the battery. Can I just pull the battery disconnect or do I need to completely unplug the battery before working on it? If I need to unplug the battery, I can just disconnect the negative wire right? Thanks.
2014 F-150 SCREW Ecoboost 4x4.
2014 Rockwood Roo 233s GVWR
thestrangebrew is offline   Reply With Quote
Old 06-14-2014, 12:51 PM   #2
fonzie's Avatar
To be on the safe side, disconnect the negative off the battery, then no surprise. Unplug shore power also.
Fonzie
Old 06-14-2014, 12:56 PM   #3
Got it thanks!
Old 06-15-2014, 09:55 AM   #4
Well I got the thermostat in and it seems to be working. The only problem I have is that when I tried screwing the backplate on, I could hear crunching in the wood and the screws were loose. So I know I have to raise the thermostat with either some new holes for the screws or mounting tape. If I were to do new holes, what's the best way? Just drill it in? The wall seems pretty flimsy.
Old 06-15-2014, 02:28 PM   #5
Seems like plastic wall anchors would work and allow you to use the same hole location with just a slightly bigger hole. They will expand when you insert the screw and hold to the thin RV plywood wall.
richl167 is offline   Reply With Quote
Old 06-15-2014, 03:02 PM   #6
rbq
If necessary use hollow door anchors. They should work on the wall for something as light as a thermostat.
2001 Chevy Silverado
2011 Rockwood Roo 233S
rbq is offline   Reply With Quote
Old 06-16-2014, 10:54 AM   #7
Thanks guys. Anchors worked wonderfully! On to the next mod!
Old 06-16-2014, 05:55 PM   #8
RedStick's Avatar
Where did you pick up the digital - if you don't mind me asking?
I'd like to convert the oem for a digital but I'd like to be able to run the fan on the low setting.
2013 Rockwood Roo 23ss
2012 F150 Ecoboost
Camped for 12 nights in 2015 - too many cancellations
Camped for 25 nights in 2014!
Camped for 24 nights in 2013!
RedStick is offline   Reply With Quote
Old 06-16-2014, 06:20 PM   #9
I ordered mine from Newegg.com: Coleman Digital Heat/Cool Thermostat (u) 8330-3362 - Newegg.com
I think they have them on Amazon as well. The only wire that didn't match up was the grey. I had to connect grey to brown instead of grey to grey if I remember right. Otherwise, super easy swap.
Edit: I tested the fan settings and was able to adjust between low & high. Seems to work perfect so far.
Old 06-16-2014, 06:35 PM   #10
RedStick's Avatar
Thanks for the feedback.
I think our coils freeze up when using the fan on high. Low seems to be better - not perfect but better.
2012 F150 Ecoboost
replacement, thermostat
