If your stepping ALL the way down on the foot pedal (I'm sure you are), then it sounds like a faulty valve. You might carefully loosen the water supply line just before the valve and see if there's any pressureized water trying to come out of the fitting. If so, then the valve is bad.
Rudy and Jenny
2014 Flagstaff V-Lite 28WRBS
2013 F-150 Eco-boost 3.55
