Old 03-28-2014, 07:40 PM   #1
Old Fella
Aussiecat's Avatar
Tongue Jack
Has anyone used the Barker 3,000 lb Electric Tongue Jack on a Roo 23SS? I don't want to buy one and then find out when we pick up our new toy in July that we can't get the beds down because it's too tall.
Aussiecat is offline   Reply With Quote
Old 03-28-2014, 07:51 PM   #2
ryand's Avatar
I would immagine that it would not be taller than your propane tanks. You could get a dimension from barker and compare it to your tanks and get your answer. Assuming you have front mounted tanks on the trailer tounge.
2011 Coachmen Catalina 28DDS
2015 Ram Bighorn 2500 6.4L
http://www.ryandethrow.wordpress.com
Nights Camped 2016: 32
ryand is offline   Reply With Quote
Old 03-28-2014, 08:06 PM   #3
Old Fella
Aussiecat's Avatar
The dealer said that the jack would have to be under 21.5 inches.
Old 03-28-2014, 08:12 PM   #4
ryand's Avatar
A quick google search of "barker 3000 mounted height" reveals a few results that indicate it is roughly 20" above the coupler. Your results may vary.
Old 03-28-2014, 08:47 PM   #5
Old Fella
Aussiecat's Avatar
Thank you, much appreciated.
Old 03-29-2014, 08:23 PM   #6
CDNWhiskey's Avatar
I had a similar challenge with my 23SS. I had to look for a unit marked as a short. Even then the clearance is close. Good luck.
CDNWhiskey is offline   Reply With Quote
Old 03-29-2014, 08:32 PM   #7
bikendan's Avatar
for my 23SS, i bought a refurbed UF 3500 because it fit quite nicely under the bunk door when dropped down.
plenty of clearance so no worries.
got it off of Ebay for a little over $100.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 03-29-2014, 08:40 PM   #8
i think that Triguy has a Barker on his Roo. I'm sure he will chime in.
2015 Rockwood Roo 23IKSS
2015 GMC Sierra 1500
Archicamper is offline   Reply With Quote
Old 03-30-2014, 07:58 AM   #9
Triguy's Avatar
I do!
I replaced my LCI that came with the trailer after the gears stripped with a Barker 3500VIP. Quieter, smoother, faster and more power. Only problem I had was a faulty switch a year or two ago. Barker sent me a replacement for free (out of warranty, too )
Back to the question at hand. It fits under my bunk on my 233S, but I'll check the height above the A-frame later today.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 03-30-2014, 05:43 PM   #10
Triguy's Avatar
Just getting back 'cause I said I would but this won't be of too much help for you. As I said earlier, I have the Barker 3500VIP jack and it is 23 1/4" above the A-frame. Too tall for your unit. Maybe this will help someone with a 23SS looking at the 3500.
I hope the 3000 works for you. Barker is a very good jack.
Scott
2012 Shamrock 233S
