Old 07-05-2016, 11:35 AM   #1
GracefulCamper
rocknroos's Avatar
Tongue weight
I am looking to buy a Roo 19. Sticker on the Roo says that the tongue weight is 394 lbs. Does anyone know what the actual tongue weight on a Roo 19 would be with propane and batteries. Has anyone ever had theirs weighted when loaded. My TV is a Lincoln MKT which is the same as a Ford Flex with the ecoboost engine. It is rated at a 450 lb hitch weight and a 4500 lb towing capacity. I know that I am going to be pretty close to the MKT rating but I have seen a Flex pulling a Roo 19 once and it looked okay. Currently I have a Roo 17 and the MKT tows it easily, but it is a lighter TT. Thanks
2015 Roo 17
2010 Lincoln MKT
rocknroos is offline   Reply With Quote
Old 07-05-2016, 11:41 AM   #2
Moderators' Assistant
bikendan's Avatar
That 394 number is fantasy.
The actual loaded tongue weight will easily exceed 450lbs.
Dan-Retired Firefighter/EMT
'07 Roo 23SS pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 07-05-2016, 11:42 AM   #3
raspivey's Avatar
You're over 450 lbs. The FR brochures say the dry weights they list are with propane and common options. Battery will add another 50 or so and you'll transfer about 12% of anything else in the camper to the front. I'd guess you'll be about 500 lbs loaded. Look at the sticker on your hitch and see if it lists a separate limit for weight distributing (which will be a must on that vehicle with that trailer ).
2012 Chevy Tahoe LTZ - HD tow package
Old 07-05-2016, 11:54 AM   #4
Mr Havercamp's Avatar
You'll transfet more than 12% of anything in the camper to the front. Its a complicated calculation but a percentage of anything in the trailer ahead of the axle is hitch weight, the closer to front the higher the percentage. I had a SOB 19'ish hybrid with the same layout and with lower dry and GVW than a Roo 19 and my hitch weight approached 700 lbs.
You need to guesstimate 600 minimum. More if you ever intend on hauling water in the tank.
No comment on the MKT capability for towing a Roo 19 other than I would not choose that combination.
2017 Roo 23WS
2015 GMC Sierra 2500HD
Mr Havercamp is online now   Reply With Quote
Old 07-05-2016, 03:46 PM   #5
Airdale's Avatar
Actually the manufacturer’s published hitch weight is a valid number for a fully loaded and evenly balanced trailer.
The manufacturer’s published hitch weight is used to validate the trailer’s certified total GAWR ratings and GVWR.
The following is a verbatim excerpt from the Federal Motor Vehicle Safety Standard 571.110, paragraph S9.2.…. “On RV trailers, the sum of the GAWRs of all axles on the vehicle plus the vehicle manufacturer's recommended tongue weight must not be less than the GVWR. If tongue weight is specified as a range, the minimum value must be used.”
When an owner takes position of the trailer the hitch/tongue weight becomes 100% their responsibility.
USN - RET - PDRL
DOD - RET - Journeyman Aircraft Mechanic
SSA - RET
Airdale is offline   Reply With Quote
Old 07-06-2016, 07:00 PM   #6
GracefulCamper
rocknroos's Avatar
Airedale I agree with your assessment. On this Roo 19 there are two axle rated at 2200# each which = 4400#. Add the published tongue weight of 394# and you get the GVWR 4794#. Which is the maximum weight of the TT plus cargo. So if the actual tongue weight would be closer to 600# then add that to the 4400# for the axles you get 6000# which is beyond the manufactures rating of 4794# for this TT. Something is not adding up.
2015 Roo 17
2010 Lincoln MKT
Old 07-06-2016, 07:26 PM   #7
Airdale's Avatar
Let's work with these specs ( http://www.forestriverinc.com/produc...age=5057&Tab=4 ).
Add the UVW and the CCC...That's the trailer's GVWR...deduct the hitch weight...that's the total GAWR. Divide by the number of axles... that's the individual GAWRs...
USN - RET - PDRL
SSA - RET
Old 07-06-2016, 10:06 PM   #8
Published hitch weights are dry numbers, not fully loaded numbers.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 07-06-2016, 11:07 PM   #9
bikendan's Avatar
2010 F250 5.4L 3.73
Equal-i-zer 4pt 12K
x2
Old 07-06-2016, 11:40 PM   #10
KMP44's Avatar
No, its an unloaded weight.
Key words here are "must not be less" or in other words must be more. All this says is the "recommended" tongue weight plus max axle weights must be more than GVWR. So all it says is the tongue plus axle capacity must be more than the GVWR - which is logical.
I don't know what recommended tongue weight is, but its not the same thing as the fictional brochure tongue weight.
My Roo's tongue weight was 850 lbs at the scale - with the WDH properly setup and the trailer level. That was more than 250 pounds over the brochure weight and the total trailer weight was 300 pounds under the max.
I think in the OP's case, there is no way the actual tongue weight will be under 450, and we don't know the payload spec on the tv, but that may be an issue as well.
2005 F-150 FX4
2013 Rockwood Roo 23 IKSS
KMP44 is offline   Reply With Quote
tongue weight, weight
