05-18-2019, 08:41 PM
Tool kit
Im picking up my 19 roo 21ssl this week and i was wondering what tools everyone keeps with the trailer in case of loose screws, bolts, etc.
Is there somewhere you can find all of the sockets, wrenches, or any other tools for specific models? Ideally i want pick them up before i get the trailer
05-18-2019, 08:52 PM
No such thing as a model-specific tool box.
05-18-2019, 08:54 PM
I figured that, I guess i should have specified better. I was wondering if there was a website or hardcopy somewhere that tells you what you need so that you can purchase it
05-18-2019, 09:07 PM
https://youtu.be/-2PWdVPuV1c
I like this guy very helpful and bit of a techie nerd
2019 Flagstaff Microlite 25LB
2021 Silverado 3500 HD CCLB
2018 Escalade ESV
2009 CTS-V
05-18-2019, 09:09 PM
Get one of those screw driver kits that have one handle & a couple dozen different bits. I have come across so many different types of screw heads working on our RVs. Some I never knew existed. Also, we once had the hitch ball start to loosen up while on a trip, and no wrench I owned would open wide enough to fit the nut. Got a 24" beast of an adjustable wrench at Harbor Freight for around $30 before coupon. The thing is great.
2016 RAM 2500 Cummins SLT Lone Star 4X4 LB
2016 Windjammer 3029W Platinum
I'm not an expert. But I play one on the internet.
You live & learn or you don't live long.
If you don't punish your children, life will.
05-18-2019, 09:14 PM
Tools.
I put together a basic tool kit from Harbor Freight for about $75.00. Their tools are great for occasional use.
05-18-2019, 09:20 PM
Get the basic tools you use around the house, and be sure you have a multimeter and know how to use it.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
05-19-2019, 10:31 AM
You'll need a Robertson (square head) screwdriver for the majority of screws. Philips won't work. Get a small Tupperware jar for all the screws you'll find courteously scattered behind cabinets.
Avoid using a power screw driver where possible to avoid stripping the holes. The cabinet over our sink had stripped screws from the factory so I drilled a couple more holes for some of the extra screws,
-- Chuck
05-19-2019, 10:36 AM
Retired Panpsychist
Following Mpouls1’s link to Jared Gillis’ videos is very worthy of your time.
Don’t forget the #2 square bit screwdriver!
Theo & Carol
2007 GoldenDoodle ("Cooper") R.I.P.
2020 Rockwood Roo 23IKSS
2015 F-150 4WD XLT SCab, 5.0L, 3.73, 36gal, HD Towing Pkg (53A), 1,980lb Payload
05-19-2019, 01:52 PM
Make sure you have a 1-1/16" socket and 18" breaker bar for your anode rod if you have a Suburban water heater.
Make sure you have an appropriate socket to fit your wheel stud nuts. And a torque wrench to go with it will help.
Something to jack it up to change a flat tire. Either a bottle jack to the frame or a Trailer Aid on the good tire to lift up the bad tire off the ground. Trailer Aids come in two heights; either get the high one (Trailer Aid Plus) or make sure the low one will do.
https://www.amazon.com/Trailer-Aid-T.../dp/B001V8UKBO
Anderson Levelers can sometimes be used. Camco also makes a version now.
https://www.amazon.com/Leveler-Ander.../dp/B01LYQ1Z8S
https://www.amazon.com/Camco-44423-C.../dp/B06XPDKJN7
Get a cheap digital multimeter, too. You can them really cheap at Harbor Freight - sometimes for free with a coupon.
Also - See this similar thread that's going now:
http://www.forestriverforums.com/for...ls-185275.html
2011 Traverse LT, 3.6L, FWD
05-19-2019, 06:57 PM
Sham183
Tool kit
Simple things like screw drivers, hammer, bungee cords, tire plug kit, small tire air compressor, tire pressure gauge, basic tool set, sockets and or lug wrench for tires. Also don’t forget something to jack the trailer up with. Duct tape, super glue, replacement tail light bulbs, drill for leveling jacks. The list could go on forever [emoji23]. And I’m sure I have listed things others may have. The thing is really there is no wrong tool for a camper. You will always find something better or easier to use or have. Others will give you ideas as well. My toolbox keeps changing every year [emoji23]
05-19-2019, 07:28 PM
Buy this stuff as you need it. Get a small notebook and jot down what you need. A small plastic tool box will keep it all together.
Some sort of Federal Law mandates a Walmart, Home Depot, and Lowes in every county of the country and they have all you need.
-- Chuck
05-19-2019, 09:32 PM
I carry this - at least what I can think of from memory:
Torque Wrench
socket for lug nuts
3/8 socket set
open/closed end wrench set
screwdrivers
square tip screwdriver
fuses
bulbs
assortment of pliers and wire cutters
hammer
allen / hex wrenches
voltmeter
adjustable wrench
heavy duty jack
etc.
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
