Old 09-01-2014, 09:25 PM   #1
Carlosrod's Avatar
Tornado Rotary Flush
Has anyone here installed a Tornado Rotary Flush system on their black water tank?
Looking to install one, but wanted to see if any anyone has an opinion about them and where is the best place to install on the tank.
Live, so that when your children hear the words Ethics, Trust, Integrity and Honor, they think of YOU!
2015 Shamrock 23 IKSS Pushing a 2015 Durango R/T. Yeah, it's a Hemi
Nights Camped - 2013/17 - 2014/24 - 2015/22 - 2016/Pending
USMC - Semper Fi
Carlosrod is offline   Reply With Quote
Old 09-01-2014, 09:31 PM   #2
Carlosrod's Avatar
This is what I had in mind.
USMC - Semper Fi
Old 09-01-2014, 09:51 PM   #3
Check out the 2nd video in Post #4 here:
http://www.forestriverforums.com/for...pty-67415.html
2011 Traverse LT, 3.6L, FWD
Old 09-01-2014, 10:50 PM   #4
Carlosrod's Avatar
Thanks Rock. Very informative.
USMC - Semper Fi
Old 09-02-2014, 05:32 AM   #5
davel1971's Avatar
works great. Simple install if your tank is easily accessible. Install about in the middle of one of the long sides. You'll be amazed it what is rinses out after the tank is done draining.
David & Lynn
Old 09-02-2014, 12:42 PM   #6
TheBigLog's Avatar
I installed one. Getting near the middle of the tank is best. I had to install it on the drain side ( the only place i could) and it work great from there too.
2013 Roo 21SS
2013 Ram 1500 Crew Express 5.7 Hemi
TheBigLog is offline   Reply With Quote
Old 09-02-2014, 03:25 PM   #7
Carlosrod's Avatar
Been seeing lots of pros and cons about it. Rock's video above certainly helped. This will be a Fall project for sure on the BW tank. I want to install one on the Gray as well but, not certain if I have enough clearance between the tanks.
Thanks for the input.
USMC - Semper Fi
Old 09-02-2014, 04:08 PM   #8
PSUFan1's Avatar
We did the same as The Big Log. I think it works well. I have no interest in sticking a rod down the toilet to flush out the black tank.
Tim & Tracy, Jennifer (20), Alyssa (15), our dog Jazy
2012 Ford F150 EB Crew FX4 3.73 gears
2017 Grand Design Imagine 2800BH
Previous: 2012 Flagstaff MicroLite 23LB
2006 GMC Envoy Denali V8 & 2005 GMC Envoy I6
PSUFan1 is offline   Reply With Quote
Old 09-02-2014, 08:37 PM   #9
keven's Avatar
I installed 2 quickie flushes in both the gray and black tank. I like not having to use a stupid wand anymore. The way my tank sat in the frame rails I had to install it on the opposite side of the drain.
keven is offline   Reply With Quote
Old 09-03-2014, 09:03 AM   #10
dado39's Avatar
Also been thinking of this upgrade any one take any pictures of the process was it difficult to do ?
2014 roo 233S. 2008 saab 97x
dado39 is offline   Reply With Quote
Old 09-03-2014, 09:15 AM   #11
TheBigLog's Avatar
Was not that hard. The hardest part is finding the right size hole saw. I would not use a large drill bit. Maybe a step drill would work, you can get those really cheap at harbor freight. Than just use plenty of silicone to seal it up.
2013 Roo 21SS
Old 09-03-2014, 09:32 AM   #12
vinmaker's Avatar
The more I see of all these black tank flushers, the more I think a simple hose with wand down the toilet is better for cleaning it out.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 10000#
Old 09-03-2014, 04:51 PM   #13
Dodge Guy's Avatar
I installed the Quickie Flush in our last 2 trailers. Similar to the Tornado without the spinning head. Either one is better than just draining without flushing!
Easy to put in if the tank is accessible. Mine is on the side of the tank about 2/3 of the way back. The back of the tank is against the frame rail and was not accessible. Still works very good!
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 09-03-2014, 04:58 PM   #14
Dodge Guy's Avatar
Except that you need to drag a hose in through the camper, or through the window if you have one. vs. a one time install and then just connecting a hose. very simple and less messy!
