02-13-2014, 11:19 AM
Towing Capacity Questions
Hi All.
My first post and I have a few simple (I hope) questions regarding what I need to know when figuring out what my vehicle can safely tow.
I have a TV with Capacity of 5000lbs.
Looking at a 2011 Roo 233S.
Specifications:
Maximum Sleeping Capacity: 10
Number Of Slideouts: 1
Length (ft-in / m): 27' 9'' / 8.5
Interior Height (in / mm): 78 / 1981.2
Base Weight (lbs / kg): 4134 / 1875.2
Carrying Capacity (lbs / kg): 1833 / 831.4
Hitch Weight (lbs / kg): 532 / 241.3
I need to know the weight factors as I think about 4100 Dry and my vehicle tows 5000 I have 900 to play with but quickly learning that this is not the case.
What else do I need to factor in when deciding how heavy of a trailer can I safely tow?
Thanks in Advance.
Myself: 37 - Wife: 33
Daughter: 6 - Son: 7 months
2002 Jeep Grand Cherokee Laredo 4.0L Inline 6
2010 Cherokee 27BH
02-13-2014, 11:33 AM
Anything you put in camper adds to the weight. Food, clothes, tools, entertainment, Etc.... Also dry weight usually doesn't include your propane, any water or pooh your carrying in the tanks. Doesn't sound like much but it does add up fast. Would help if we knew your tow vehicle details?
02-13-2014, 11:58 AM
Anything you put in your camper AND anything you put in your tow vehicle excluding the driver adds to the total of cargo carrying capacity.
For example 3 kids a wife and a dog plus anything in the bed of your truck deducts your "tow" capacity numbers.
You really need to look at your cargo carrying capacity on your truck door jamb sticker.
It with the tire loading info.
You'll likely exceed that before anything else . Period.
I'll post an example of my ccc sticker.
TURBS
Goshen is my playground.
The last man standing also has a sharpie
02-13-2014, 12:01 PM
Here's mine.
Passengers and loaded equipment including hitch weight should not exceed this number. "2448"
TURBS
02-13-2014, 12:20 PM
Here are a few specs I could find online..
MAXIMUM TOWING CAPACITY** 5000 lbs.
GROSS WEIGHT 5150 lbs.
CURB WEIGHT 3786 lbs.
MAXIMUM PAYLOAD** 1100 lbs.
It's looking like I need to trade up for a bigger TV.
What is everyone's opinion of using it this year and trading in next year.
Is it possible to pull the Roo if It's practically empty, I am only travelling about 200KM max per trip.. I drive slow.. flat roads, etc etc etc..
Could I 'get away with it'? Terrible I know but I really don't want to pass on this trailer. It's a really great deal.
Thanks again for all the replies.
2010 Cherokee 27BH
02-13-2014, 12:38 PM
Your max payload will be eaten up quick.
Hitch weight alone on the roo before loading one single item is half your cargo carrying capcity. 500#
150# for reciver hitch weight distribution and sway bars.
TURBS
02-13-2014, 12:43 PM
Thanks in Advance.
Hi Jamie,
The dry weight on the yellow sticker of my 233S says 4,464lb. As I recall, that was 332lbs more than the listed brochure dry weight due to the factory installed options. My factory options included (going by memory here): The convenience package, power awning, slide out toppers, power jack, spare tire, and raised fridge panels.
Along with the "dry weight" you will load quite a bit of extra cargo into the new trailer, which will increase it's weight. Plan on something like 800-1,200lbs of clothes, cargo, water, batteries, propane, food, refreshments, etc. It adds up fast.
Your trailer might come out to as little as 5,000lbs loaded, but that is unlikely. I would guess the loaded weight of your 233S will be closer to 5,300 plus.
Yes, you will. You will be over a few ratings for that truck, including the tow cap and the payload. The payload number has to be high enough to account for all of the people and cargo in the truck plus the hitch weight, which is 650-750lbs on mine depending how I load.
Anything is possible, but is it practical? Towing completely empty (no food, no cargo, etc) is not really how I envision my camping trips. I think this would quickly take the shine off of camping for me YMMV.
Still, that's a better option than towing over your ratings.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
02-13-2014, 12:51 PM
I forgot all about the yellow sticker... Took a pic yesterday and just checked it... 4513lbs..
I think I need a bigger TV.
2010 Cherokee 27BH
02-13-2014, 01:08 PM
If you are going to get a bigger TV, get one that will handle a larger TT also.
2018 Flagstaff 29KSWS
2008 Ram Laramie 3500 Megacab 4x4 Cummins 6.7L Turbo Diesel
02-13-2014, 01:33 PM
I concur ............. buy a tv for your next "bigger" tt
02-13-2014, 01:40 PM
We started in the same position. Santa Fe with a 3500 towing max. Once we started looking at HTTs we realized we needed a bigger TV. Got a great deal on a F150 SuperCrew (originally looking at the Explorer but we realized it wouldn't handle it)...that was with the anticipation of looking at HTTs this year. We got lucky and the local dealer wanted to sell us a 233s they had on the lot.
I feel the Roo behind the F150...I know she is there. I can't imagine ever having tried to tow it with the Santa Fe. I have seen some people pull into campgrounds with Escapes, Explorer, Pilots and Santa Fe's pulling smaller HTTs and they all have said it's a rough ride and they are waiting to get a 1/2 ton pickup as their next vehicule.
We load the Roo, load the truck and load the family and we don't have to worry about weight....ever.
2013 F-150 XTR Ecoboost 4x4, 3.73 w/Equalizer
2014 Roo 233s
Nights camped 2014: 28
Nights camped 2013: 17
02-13-2014, 03:16 PM
No way. I'm pull a 233s with a suburban towing capacity of 7000 and I'm pushing it because I have 5 kids. 6 bodies, excluding driver, is taking away from my towing capacity. And the GVWR is over 5000lbs for the 233s.
Kristina
2016 Rockwood Premier 2317G
2021 F150 XLT
Previously:
2005 Fleetwood Seapine, 2012 Rockwood Roo
2015 Sunseeker, 2017 Fleetwood Pace Arrow
02-13-2014, 04:01 PM
the OP needs to get a bigger TV or a smaller trailer, no just "think" about it.
02-13-2014, 04:07 PM
FYI,
Do the math. Here is a link that is very eye opening.
Tow Vehicle Sizing
02-13-2014, 04:43 PM
If it truly is a deal you don't want to pass on and you want to wait a year on the bigger tv, maybe consider a seasonal site for this summer. Most dealers will be willing to tow it to a seasonal site and you could probably work out a deal for them to move it to wherever you store it for the winter.
2022 Columbus 379MBC (Previous 2013 Rockwood Roo 23 IKSS)
2023 F-350 (Previous 2017 F250, 2005 F-150)
02-13-2014, 05:31 PM
Engineer of Crazy Train
My setup, and I feel that I am pushing it. After going to the CAT scales, I am 100lbs over GVW. I am workkng on that, but I am in the market for a new TV, and sizing it to my next TT.
Sent from my GT-N5110 using Forest River Forums mobile app
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 - 18
Come read my Camping Blogs
02-13-2014, 06:29 PM
If your tv has P rated tires, I wouldn't even consider it, if it has LT LR D or E tires, I'd give it a whirl. Tires are a lot cheaper than bigger trucks.
02-13-2014, 07:30 PM
An excellent idea! That also gives you plenty of time to look for a good deal on a tow vehicle, while you sit around a campfire, sipping on a cold beverage.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
02-13-2014, 08:12 PM
Phat Phrog Stunt Crew
Buy a TV bigger than you need. I didn't make my first payment on my 2013 Silverado 1500 and DW found a gotta have 5er to replace the TT. But the new truck won't pull it.
2014 Wildcat 327ck
02-13-2014, 08:52 PM
Thanks for all the replies.
Really great advice from everyone.
Cheers.
2010 Cherokee 27BH
