Old 09-05-2012, 03:42 PM   #11
Triguy's Avatar
This is the second time today I read complaints about a Yukon/Suburban struggling while crawling up grades. Here's the other thread Airlift 1000 are junk.
Xtrmtj - I really think its the truck or how its being driven. I also think you should use a WDH for that trailer but for other reasons. I can't see how a WDH will help with the problem you described.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 09-05-2012, 03:57 PM   #12
TURBS's Avatar
I bet the gear ratio is in the low threes and would explain a lot !
Take a suburban with a 323 ratio and a 5.3l engine and the same suburban with a 350 or 373 ratio and the same 5.3 engine and it would be night and day difference!
Old 09-05-2012, 06:00 PM   #13
Triguy's Avatar
Methinks you're right.
Scott
2012 Shamrock 233S
Old 09-05-2012, 06:08 PM   #14
It is a 3.73 rear end gear ratio. 4657 gvwr also
2007 Yukon XL (AKA) LAND YACHT
2002 Rockwood Roo 23ft
1998 Jeep Wangler (lifted and modified)
2008 Pontiac G6
Xtrmtj is offline   Reply With Quote
Old 09-05-2012, 09:20 PM   #15
Triguy's Avatar
Well, there goes that theory. A 3.73 rear end shouldn't be the problem.
That can't be the GVWR, though. That number is too low for a Yukon XL 4X4, which should be closer to 7,000-7,500lbs. Are you sure about that? The Gross Vehicle Weight Rating (GVWR) is the maximum a vehicle can safely weigh when loaded, including the vehicle itself, occupants, cargo and optional equipment.
Is that the trailer GVWR?
Scott
2012 Shamrock 233S
Old 09-05-2012, 09:22 PM   #16
TURBS's Avatar
Hmmmmmmm
Old 09-05-2012, 09:30 PM   #17
I've not been feeling the love for my 2012 Suburban this week. I have the 3.42 diff. Think that's the highest (?) you can get in the 1500 these days. Aerodynamic drag may be a factor. This truck is definitely over 3 tons. My Sunset Trail is about 2200 lbs heavier, but tows a lot better than my Surveyor 189. The Sunset Trail has a curved fiberglass front cap, the Surveyor has a flat front. With either though, in the hilly terrain of the Carolinas, expecting to cruise above 60 mph is just too stressful unless you enjoy the sound of a screaming V8. And 8 mpg is just gravy for the goose.
crasher is offline   Reply With Quote
Old 09-05-2012, 11:14 PM   #18
bikendan's Avatar
well, i pull my Roo 23SS with an '07 Avalanche, basically the same as the Yukon, except with a pickup bed.
i have the 5.3 with the 3.73 that comes with the factory tow package. but the early GM900 models had the 4 speed tranny, whereas the latest ones have the 6 speed tranny but higher rear end ratios.
but i live in California and pull through mountains all the time, including the Sierras, Cascades and Siskiyous.
my 23SS weighs around 5000lbs. loaded for camping and i have no problems towing in the mountains.
i really don't pay much attention to the rpms, since the 4 speed will require it to rev higher on steep grades.
i have plenty of power and the only issues is the tranny runs a little hot, even with the factory tranny cooler.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 09-06-2012, 08:32 PM   #19
The weight I did post was for the trailer...sorry.
I think I really had unrealistic expectations on the towing at 65mph. I just need to relax and drive, get ore towing experience and one on.
I don't feel as though my step warrants a wdh, my Yukon doesn't squat and I have no issue with steering. Plus it won't help pulling the weight will it?
I am already using a friction sway bar to.
Keep the info coming please.
2008 Pontiac G6
Old 09-06-2012, 08:43 PM   #20
caper's Avatar
I tow the mountains in western Canada. I try to keep my RPM's in the mid to low 3000. By the time I get to the top of the hill my speed drops to 40 mph. I could keep a higher speed but why make the truck work harder then it has to.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
