Old 05-20-2016, 07:02 PM   #11
DaveSchwartz's Avatar
Locked wheels 'hopping' on wet pavement is a possible explanation for the vibration you experienced in that case. Its possible this would happen on dry pavement too... we've probably all seen the double-dashed line skid marks left when a transport locks wheels.
I wouldn't expect grease-fouled brakes... the OP said the trailer is new and its quite unlikely that the dealer would have added grease to a just-delivered trailer.
Its possible its adjustment but just a bit suspicious that only the front axle is affected and apparently each side equally. Personally, I've never adjusted a trailer brake in my life.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 05-20-2016, 08:11 PM   #12
lesptr's Avatar
Mine did, (or it was done at the factory) and I had only one operational brake until I decided it was time to repack my bearings. The one brake that was working was completely worn and had to be replaced. It IS one possible explanation to the OP. No power to to one axel is another. Both should be checked.
2017 Coachman Chaparral 336TSIK
2015 F350 6.7
lesptr is online now   Reply With Quote
Old 05-20-2016, 10:39 PM   #13
Could also be that the juice isn't getting to the front axle brakes. Several posts here about wires to the brakes either not being connected or being broken. So check your wiring. Also: There is typically one wire going in (from the 7-pin connector) and one coming out. The one coming out is usually just grounded to frame. Several posts about the ground wire not being adequate connected to the frame or being broken. So you need to make sure BOTH wires are good.
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
brakes, trailer
