Old 03-19-2012, 11:28 AM   #1
RoadDog66's Avatar
Trailer Jack?
Do the Rockwood Roo's come with a standard wheel jack for tire changing? Or do you use the front/rear stabilizer jacks to raise it?
I do have a 2-ton hydraulic jack I can drag with me, but it adds about 50-lbs of weight to carry along.
TV: '15 Ram 6.4 Hemi CC 4x4
Old TT: '12 Rockwood Roo 19 (sold)
New TT: '14 CR Sunset Trail 290QB
WD: Equalizer 1200/12K
BC: Ram OEM
RoadDog66 is offline   Reply With Quote
Old 03-19-2012, 11:32 AM   #2
TURBS's Avatar
Do not use stabilizers to raise your camper!
they are called stabilizers for a reason!
Use a bottle jack.
Old 03-19-2012, 11:34 AM   #3
X2 on the bottle jack
2015 Dodge Ram 1500 Quad Cab 4WD w/trailer pkg
345HP 5.7 Hemi/8spd Auto/3.73 Rear
2010 Roo 23SS
Prodigy Brake Controller
Equal-i-zer WD Hitch
2003 Harley FXDX Super Glide
browne02 is offline   Reply With Quote
Old 03-19-2012, 11:37 AM   #4
TURBS's Avatar
The REAL debate here is where to jack from!
Everybody has there own opinion on that!
Old 03-19-2012, 11:56 AM   #5
RoadDog66's Avatar
So they don't come with one as standard equipment?
I need to buy one, right?
BC: Ram OEM
Old 03-19-2012, 11:57 AM   #6
Triguy's Avatar
It does not come with a jack.
As others have said, you will bend your stabs is you try to lift the camper with them.
I carry a 6-ton bottle jack in case I needed to change a tire on my trailer. There are other ways of doing it such as driving one tire up onto something so you can change the other. There was a good discussion on the forum earlier this month.
Replacing a tire on a trip + tools?
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 03-19-2012, 11:57 AM   #7
TURBS's Avatar
NONE that I have seen come with a jack of any kind !
user supplied .
Old 03-19-2012, 12:04 PM   #8
RoadDog66's Avatar
Ok thanx. I figured it would come with something since it has wheels/rims, but I'll drag my hydraulic for now until I can get a bottle jack.
For a 4000-lb TT what weight limit would you recommend? Is 2-ton enough since it's only raising one side?
BC: Ram OEM
Old 03-19-2012, 12:05 PM   #9
MtnGuy's Avatar
I think the general consensus of the members here is to jack the trailer via the frame between the 2 axles.....that is where I do mine.
Old 03-19-2012, 01:00 PM   #10
Triguy's Avatar
Too little jack for my comfort. I say double the weight of the trailer. So a 4-ton (8,000lb) bottle jack for a 4,000lb TT. They are pretty cheap at that size. My 6-ton was $25 (I paid $20 when it was on sale).
Scott
2012 Shamrock 233S
