Old 04-12-2015, 08:57 PM   #21
wicked1's Avatar
Oh😱 may be time to get the BFG's sooner then later?
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
Old 04-12-2015, 09:13 PM   #22
Stormrider151's Avatar
I'm going this week and have LT E's put on my truck before my new trailer gets here. All that wiggle and squirm from the P's is irritating.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 04-13-2015, 08:47 AM   #23
wicked1's Avatar
Ah so that is what is causing the wiggle and swishing around? The hitch is set perfect but not sure why I had some of the wiggle going from NJ to VA and back especially that the Roo is 1700#'s lighter and I have a 1000# TW hitch setup for a 750# TW on the Roo
Old 04-13-2015, 09:20 AM   #24
B and B's Avatar
I can barely fit 285's on my F150 vs stock 275's. 305's sound big to me. The 285's afford me less clearance for ice buildup in the winter.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 04-13-2015, 09:22 AM   #25
B and B's Avatar
Been there , Trailer Dealers know nothing about sway reduction P vs LT tires. This forum provided the education required. Jacking the air up to 44 psi on the P Perrelli's helps but not the same as LT tires.
Old 04-13-2015, 09:31 AM   #26
cogito ergo moo
Cowracer's Avatar
Suggestion:
When safe (on a straight highway with lots of room) try to watch the trailer in the side mirror. Pick a spot of dirt or something on the mirror, and line up the rear corner of the trailer with it. When the Reese Dual-Cam is set up correctly, there should be zero movement relative from the trailer to the mirror. It should look like you are driving a solid, one piece unit. It's kinda hard to describe, but when you see it, you will know what I am talking about.
If the corner of the trailer is moving around relative to the mirror, then you are getting some angle at the hitch between the truck and the trailer, and you need to redo your setup. IF it isn't moving, then your wandering is most likely a tire issue.
I run the Dual-cam and I have no sway or "angle" between the truck and trailer on straight roads.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
2016
Rockwood Signature Ultralite 8329ss
Rallies Attended:
Cowracer is online now   Reply With Quote
sway, trailer
